Question about KitchenAid KERA205P Electric Kitchen Range
NEED TO FIND OWNER'S MANUAL
I JUST BUY KITCHENAID KERA205P ELECTRIC RANGE,AND I
NEED TO FIND A OWNER;S MANUAL,TO LEARN I TO USE THE
RANGE.PLEASE LET ME NOW WHERE TO FIND ONE.
  • njb1054 Mar 10, 2009
    All I want to know is how to get an owners manual.
Connections for texecom veritas 8 intruder alarm
Posted on Dec 13, 2009
    President:
  • KitchenAid Master
  • 2,651 Answers
One burner on Kera205pbt won't heat
Just to be clear, the burner does not heat at all? Is this the small or large burner? Swap the burner with another one to see if it is the burner itself or the infinite switch. Post back your results.
Feb 08, 2013 | KitchenAid KERA205P Electric Kitchen Range
Trying to set Sabbath cooking mode, no instructions in manual
copy and paste this site......http://www.retrevo.com/search/v2/jsp/pdfViewer.jsp?doc=404215aeb4c28c12002f177f0d2004f4&page=20§id=41&q=KitchenAid+KERA205PSS+sabbath+mode
May 08, 2011 | KitchenAid KERA205P Electric Kitchen Range
My oven is working but the stove elements are working, no lights come on and the elements don't get warm? Could it be a fuse? If so where would i find it?
Sorry to read about your problem, I hope this helps you out.
nope no fuse..check to see that your circuit breaker or ok..flip them on and off, just dont look at them
you may have defective coils
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | KitchenAid KERA205P Electric Kitchen Range
Display reads EO -F2- stove top works, oven will not
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
Self Clean will not work. F5E1 Latch not operating
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 21, 2010 | KitchenAid KERA205P Electric Kitchen Range
Can't find my owners manual for my kitchenaid stove electric with bottom warming drawer - need to do a self cleaning and don't know what to do? Do I need cleaning product and how long will it take?
If the model number is correct, you can find your owner's manual (with self cleaning instructions) and installation guide listed at managemyhome.com. Just type in the model number under the "Manuals" link and your manuals are available in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Nov 27, 2009 | KitchenAid KERA205P Electric Kitchen Range
I get an F2 E5 error on my panel, what is wrong? the bake does not work.
As per Manual :-
F2 E5 - Cancel key drive line open.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | KitchenAid KERA205P Electric Kitchen Range
Convection oven fan is making noise as if hitting fan shroud on start-up and when door is opened.
Either the blades have moved out on the shaft or there is excessive shaft play allowing it to hit when there is not much pressure as during start up and when the door is opened.
Eric
Jul 16, 2009 | KitchenAid KERA205P Electric Kitchen Range
KitchenAid KERA205P Electric Kitchen Range Logo
358 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
