Installing a new aftermarket Nav system need wiring diagram
If it is the wiring diagram for the Escape you need, here it is:
12 VOLT CONSTANT
Connect to BATTERY ONLY
STARTER
TAN/LIGHT BLUE (+)
IGNITION SWITCH HARNESS
STARTER 2
N/A
IGNITION 1
LIGHT GREEN/PURPLE (+)
IGNITION 2
N/A
IGNITION 3
N/A
ACCESSORY/HEATER BLOWER 1
BLACK/LIGHT GREEN (+)
ACCESSORY/HEATER BLOWER 2
N/A
KEYSENSE
N/A
PARKING LIGHTS ( - )
WHITE/BLACK (-)
@ SJB, Connector E, Pin 4, See NOTE *1
PARKING LIGHTS ( + )
BROWN (+)
@ SJB, Connector C, Pin 19, See NOTE *1
POWER LOCK
PINK/WHITE (1-Wire System) See NOTE *2
@ SJB, Connector D, Pin 22, See NOTE *1
POWER UNLOCK
Same wire, See NOTE *2
See DIAGRAMS
DOOR TRIGGER
PINK (-)
@ SJB, Connector C, Pin 28, See NOTE *1
DOMELIGHT SUPERVISION
USE DOOR TRIGGER
TRUNK RELEASE
N/A
SLIDING POWER DOOR
N/A
HORN
YELLOW/LIGHT GREEN (-)
@ SJB, Connector A, Pin 14, See NOTE *1
TACH
NOT RED or WHITE/RED
@ IGNITION COIL or FUEL INJECTOR
WAIT TO START LIGHT
N/A
BRAKE
LIGHT GREEN (+)
@ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM
DARK BLUE/LIGHT GREEN (-)
@ SJB, Connector D, Pin 3, See NOTE *1
ANTI-THEFT
FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM
TRANSPONDER @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE *1 The SJB (Smart Junction Block) is the FUSE/RELAY BOX on the PASSENGER SIDE of the CENTER CONSOLE. NOTE *2 This vehicle uses a 1-Wire Door Locking System, LOCK requires a (-)Negative thru a 1000 Ohm Resistor and UNLOCK requires a straight (-)Negative
aftermarket = many brands.
Please reply with the make&model # so I can help you.
The unit did not have a manual?
