Question about Brother DCP 1000 All-In-One Laser Printer
Problems my copy machine is working but i am not able to print can you tell me how to get this working
Go to START: click Settings; click on printer and faxes; look for an icon to your All in one printer; if it is not there, you must load the software provided to you when bought; or; connect your printer to the computer using the parallel cable or other high speed USB cable and turn on your computer, software should load automatically; then the computer will ask if you want to use this printer as your default; Click Yes! your all set
Posted on Aug 22, 2008
Hi dear sir I have Ricoh 700 machine it was working fine but yesterday it's got some problem when I switch on its showing ready when i make the copy its scan the paper but not print stay on same place but...
You should try resetting the machine if you can. Taking out power cord will not reset machine. The micro chip has to be reset on the machine. If test / counter print works but copy doesn't work, then reset machine.
Nov 26, 2014 | Office Equipment & Supplies
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
How can we tell if our fax machine is working
basically if the fax is well kept, its dialing properties will remain ok. what you need to check is the quality of print out. to test the quality of print out just try to copy a sample document. if your fax is a thermal type, change the paper first before proceeding with copying. if your fax has a menu and help button try pressing the menu first before help for the fax to print a helplist.
Mar 28, 2009 | Office Equipment & Supplies
Can't fax out on my Epson Stylus CX5800X
Verizon is lying to you. Fax machines are analog devices.
Mar 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP Photosmart 7760 printer won't print on colored paper??????
hi icymay,
on photosmart machines you have different trays for different sized media. try placing it on the one for envelops tray or on the regular tray towards the left corner. try copying first if that works try printing from the pc. you may need to change the paper type if it fails to start the print job.
cheers
Oct 10, 2008 | Gateway (4000635) Motherboard
All copies are blank
What happens when you print a report? Do you get print then? If you can print reports and then you get blank copies the problem is your scanner. If you can't print or copy, then the problem is in either the drum, I would say 30 percent, or laser probably 70 percent.
But we have to find out if it will print a report. Do you use the machine as a fax ? Do they print ok?
Sep 29, 2008 | Xerox WorkCentre M15i Laser Printer
KONICA 7020 - Blank copy
I have never heard of a developer moving backwards!!!!!!!!!!!!!!!!???
the motor that runs it, the .... there is too much involved to mention. A developper moving backwards will spill so much toner in the machine anyway.
If you get a copy and then it goes blank, that tells me you have a problem with the SEPERATION UNIT, it may be shorting out causing the paper to rise against the drum giving you blank copies.
A blurr copy tells me there is a problem with the Scanner/Optics area. maybe the rails that the scanner run on are too dry or has a problem, the optics(mirrors) may be misaligned.
Not sure what you mean by (hanging) ??
Jul 31, 2008 | Office Equipment & Supplies
Fax printing
it can be sender side problem.
Apr 23, 2008 | Lexmark X215 MFP All-In-One Laser Printer
"maintenance needed" after so many copies
I hate this machine. Right now I can't print. It tells me to change the tray when I try to print.
Mar 13, 2008 | Sharp AR-M162 All-In-One Laser Printer
Printer and Making Copies does not work!
Will the machine run a paper path test?
This sounds like it could be a sensor indicating a paper jam, if this is the case, it won't run anything through the paper path (not even a blank page).
Nov 26, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
Brother DCP 1000 All-In-One Laser Printer Logo
44 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
