Question about RCA CDRW120 2-Disc CD Recorder
Volume fades away to no volume
There is no volume when trying to copy music from LP Record.
    Brigadier General:
  • 8,546 Answers
Is this problem only with recording or does your LP also NOT have useful volume for normal listening?
What kind of turntable is it? if it's a traditional unamplified turntable you can't just jack it into any old recording device. The small signal produced by a phono cartridge requires the pre-amplification provided by a Phono preamp (either standalone or in a receiver). The Phono section also applies a specific RIAA equalization curve to the phono output to make it sound 'normal'.
Posted on Apr 08, 2009
    Genius:
  • 1,199 Answers
I think the problem is you need a pre-amp for the record player to increase signel strength !Make sure you are useing some kind af amp in between player and recorder!
Please rate my response
Thank
You!
Posted on Jan 06, 2009
How do I record music on my OGM
Sounds like you may have the volume too high on your music. Try moving away from the speaker and lowering the volume.
Apr 09, 2014 | AT&T 1717 Digital Answering Machine
I have had Roxio Creator 2011 for 3 years and have been able to copy many of my vinyl Lp's onto the system. However I have not used it for about 8 months and when I tried to 'record' some more LP's I...
If you didn't install the driver of the USB record player, it won't pick up all but the basic functions of the unit. try upgrading the driver of the LP usb player.
Nov 18, 2013 | Roxio Creator 2011
The unit is connected to a TV via HDMI lead. I am trying to record from an LP record player to dvd via the front connection of the dvd recorder, it is recording but at very low volume?
hi,
You need a phono pre amp between the Recorder and LP. The audio out put of LP player is very low. that why the volume is very low. You should amplify it using a phono pre amp and then connect to the recorder's input.
ok
Aug 10, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
When recording live music the tone quality fades in and out when the music gets loud/soft- How can I record a constant sound level without this fade/compresion. Thanks
Option 1:
Check your audio settings on your camcorder. You may have an option to zoom in on the sound or record sound all around you. Try switching between either of those and see if that helps.
Option 2:
Add an external microphone
Option 3:
Try to muffle (lightly cover up) your onboard mic to keep the loud sounds from auto adjusting the volume.
Jan 11, 2011 | Panasonic NV-GS35 Mini DV Digital...
My Laney VC30 Guitar valve amps volume keepd fading in
CHANGE THE TUBES. ARITHEBASSPLAYER
Mar 25, 2009 | Music
I have a lot of music on tape cassettes
You will need three things.
1. Cassette player with a mini headphone jack
2. cable with male mini jack at each end. (usually can find at a dollar store.)
3. Audacity (Open Source audio program)
Hook up the cable to your cassette and to the line in on your sound card. Turn volume on cassette player to 3/4 or so.
Download and install Audacity. Press play on the cassette player, press the record button in Audacity. When done press stop, and under the File menu you can Export to an MP3. You can read the Audacity help menu for more options on copying and pasting to create a new file for each track, and for fading in and fading out to get a smoother start and finish to each track.
Mar 12, 2009 | Apple iPod nano
No Sound
Install the sound driver, (which can be found in the mother board's companion CD)
make sure in the "volume control" window of control panel that the mic volume and other volume indicators are full before trying to record.
Apr 12, 2008 | Gateway 506GR PC Desktop
Speakers fade in and out when listening to music
ensure all connectors are properly inserted, then if you have a speaker mounted volume control, then run it back and forth rapidly about 100 times with power off. this will allow the tiny copper "wipers" contacts to brush off any accumulated dust.
May 25, 2007 | Dell 5650 Computer Speakers
When turning on screen fades away then restarts automatically
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 09, 2007 | SanDisk Sansa e260 MP3 Player
Volume
Your MD player probably isn't LP capable. Attempting to play an LP recorded MiniDisc in a player that is only SP capable will produce no sound even though the display (time counter, track name) looks like everything is operating properly. Record the MD you were attempting to play in SP and you will get sound.
Mar 05, 2006 | Pioneer MEH-P5000 MiniDisc Player
RCA CDRW120 2-Disc CD Recorder Logo
108 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
