Question about Canon imageCLASS D320 Digital Copier
Lines across paper when photocopying on a canon #D-320
Have a canon Model # D-320, changed ink cartridge and there is still lines that go across paper. is there a cartridge drum in this copier and if there is where and how do you replace. I'm looking this up for my father in law. any help is great. thanks
  • 1 more comment
  • Anonymous Feb 10, 2009
    Random lines running across the paper, sometimes just one, sometimes a whole bunch & a new copy is needed. Happens before & after cartridge replacement
  • nosoup4uever Feb 14, 2009
    I have the same problem. A vertical black streak along one
    side of my copy.
  • purple84 Feb 18, 2009
    The line runs vertical down the page on the office copier, I cleaned it and it is still there. But when I put a piece of paper on the platen glass the line does not appear. Can't figure it out and cleaned where the instructions said.HELP
  • 57 Answers
Take it back to the store or call the canon customer service
Posted on Jan 06, 2009
Why do my pictures have lines across them?
Try running one or two ink cartridge cleaning cycles to help clear the air out of the ink nozzles. New cartridges aren't always perfect to begin with. After doing the cleaning try running a test print from your printer setup or installation properties window. If this print is good try printing another picture on a plain piece of paper rather than photo paper. If it prints OK then use your photo paper. I say this so you don't waste your photo paper. If you get lines in the test print, return the cartridge and see if the place you bought it from will exchange it for another one. If they will not exchange it try to get them to make the cartridge print correctly. You may have to bring your printer to them. This is the best advice I can give you, I hope it helps.
May 27, 2015 | Canon PIXMA Office Equipment & Supplies
Canon i560 colour printing problem
have you tried changing the cartridge..?
Jul 29, 2008 | Canon Office Equipment & Supplies
My printer misses lines when printing.
Definitely a partial clog. Remove your ink cartridge and take it to your microwave. DO NOT PUT IT IN THE MICROWAVE. Fold up some paper towels and apply enough water to the towels to get wet and damp but not dripping. Heat the wet towels in the microwave to get very hot (about 30 seconds). Now, place the cartridge on the steamy hot paper towel and let the steam and hot water dissolve the dried ink. After the towel cools drag the ink contacts across the wet paper towel and look for a smooth and even line of ink. One smooth wide line for black and three smooth lines for the color . Try the drag test on some dry paper towels for the final test. If necessary repeat the whole process again. For stubborn and very old cartridges let set on the wet towel for several hours and recheck. Good Luck.
Dec 29, 2014 | Canon PIXMA iP1000
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Ink cartridge
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Sep 16, 2009 | Canon BubbleJet i320 Printer
Not printing
did you remove the safety tape from the cartridge ?
Dec 23, 2008 | Office Equipment & Supplies
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
Canon imageCLASS D320 Digital Copier Logo
137 people viewed this question
old marine
old marine
