Question about Brother MFC 240C All-In-One InkJet Printer
Where is the ink cartridge?
I do not know where the ink cartridge is locatedlcan you show me where?
  • Anonymous Jan 08, 2009
    can you show me a picture of how to change the ink
    President:
  • 8,637 Answers
It is on the FRONT RIGHT PANEL, See below. Bud
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in. If the display continues to show NO CARTRIDGE, continue to Step 2.
  2. Open the ink cartridge cover. Pull the lock release levers down and take out the ink cartridges.
  1. Reinstall the ink cartridges and lift and push each lock release lever until it clicks, then close the ink cartridge cover.
Posted on Jan 07, 2009
How to clean ink cartridge
With isopropyl alcohol highest % as you can get.
Dec 17, 2012 | Office Equipment & Supplies
How do i change my ink cartridge on my mfc-295cn
Hello and welcome to FixYa;
  1. Open the ink cartridge cover. If one or more ink cartridges is empty (for example Black), the LCD shows "Cannot Print (Replace BK Ink)" or "B&W Print Only."
  2. Press down on the release lever to unlock it and take out the ink cartridge for the color shown on the LCD.
  3. Open the new ink cartridge bag for the color shown on the LCD, and then take out the ink cartridge.
  4. Turn the green knob on the protective yellow cap clockwise to release the vacuum seal, then remove the cap (1). You must hold the ink cartridge as indicated in the picture below.
  5. Each color has its own correct position. Insert the ink cartridge in the direction of the arrow on the label.
  6. Gently push in the ink cartridge until it clicks, and then close the ink cartridge cover.
  7. The machine will automatically reset the ink level.
I am sending you the link that shows you illustrated pictures to help you through this.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000030/faq000230_012.html?reg=us&c=us&lang=en&prod=mfc295cn_all&Cat=7
You should be good to go!
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
May 30, 2011 | Brother IntelliFax Fax/ Phone/ Copier
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
How to reset ink level canon iP 2772??
Download and run the ipTool to reset your ink level :
http://www.mediafire.com/?nmj5nnzzjaw
Features IP Tool software:
  • Showing all info on the printer such as ink level, ink counter number of cleaning, cartridge replacement and more.
  • Print test feature to test nozzle on the cartridge.
  • Cleaning and deep cleaning feature to clean head cartridge and cleaning the rollers.
  • Changing the delay value for drying.
  • Set the printer model manually.
  • Reading and reset EEPROM printer.
  • Reset counter and reset ink level on the color and black cartridges.
Ink Level - shows the level ink:
  • BK - black cartridge.
  • CY - Cyan cartridge.
  • MG - Magenta cartridge.
  • YL - Yellow cartridge.
  • WM - Waste ink counter status.
  • WP - "additional" waste ink counter status.
Port Name - displays the port where the printer installed.
Port S / N - shows the serial number of the printer port.
Power - shows the number of:
  • ON - inclusions printer.
  • OFF - to turn off the printer.
Cartridge Info - Displays information status of:
  • CL - colored cartridge.
Head Parking - displays the number of parking.
Head Cleaning - shows the number how many time the cartridge cleaned.
Head Deep Cleaning - displays the number of deep cleaning Printer cartridge.
Cartridge Replacement - shows the number of cartridge replacements:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 20, 2010 | Office Equipment & Supplies
Printer doesn't revognize new ink cartridge
Are you using Dell Series 5 ink cartridges? Dell Series 5 ink cartridges have a cartridge that cannot be reset.
Article on refilling Dell ink cartridges
It's possible to get a bad Dell Series 5 ink cartridge. Return to place of purchase for a replacement.
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
5183 INK problem
You need to go into printer options in the Windows control panel. Chose properties, and find the option to install a new cartridge. Follow the onscreen instructions.
If you need more help, please tell me which version of Windows you have.
Sep 19, 2009 | HP Photosmart C5180 All-In-One InkJet...
Epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
Sep 18, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Estimated ink levels are incorrect
The simple solution is to buy the HP cartridges. Often times,.. MOST times, aftermarket ink cartridges and refill kits are an inferior product. The difference is not always noticeable right away, but almost always rears it's head in the end. This is usually due to the ink being of a different viscosity than the original ink. Which leads to sloppy prints, sensor errors, leaky or dead jets.
Personally I recommend everyone buy Laser printers. With prices where they are these days, there is no reason for anyone to buy an inkjet printer. Lasers will cost more up front, but are much cheaper per page and generally longer lasting.
Feb 15, 2009 | HP PhotoSmart C4280 Laser Printer
Canon Smart base MPC 400 Printer
This printer needs these cartridges: -
1. (BCI-3eB) Black Ink Cartridge,
2. (BCI-3eC) Cyan Ink Cartridge
3. (BCI-3eM) Magenta Ink Cartridge
4. (BCI-3eY) Yellow Ink Cartridge
I think you need to clean your cartridge connectors with alchohol and retry.
Nov 21, 2007 | Canon SmartBase MPC400 All-In-One InkJet...
Ink replaced, but sows nothing
A yellow exclamation mark in any application means the attatched item to it is usually in error state, but you say the printer works fine. Most people would tell you to not touch what is working!!! But leaving anything showing error risks further confusion and problems. I think that you problem is probably very simple. Do you know hao to reset your ink levels. Read your manual that came with disk or go to the onscreen help. You may find this will remove the issue. If it does not, then you may have a corrupted driver etc, and may need to uninstall the printer, and reinstall it again. Good luck.
Aug 30, 2007 | HP Photosmart C3180 All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
