SOURCE: won't boot indicater lights blink 4 times
does it do anything with ac power and battery removed ,same flashhing? if it does the flashing this is a hardware failure of some kind. just because it flashs 4 times may or may not lead to the true cause . if you have a extra memory stick , i would try using 1 stick at a time if your laptop uses 2 sticks.
Now if it does nothing at all you may have a power adaptor or dc jack problem .
SOURCE: Acer one AOA 150 Power light comes on and thats its no lights
There are approx 6 reasons why this might happen:
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
SOURCE: My Acer AOA 110 does not connect wireless nor does
there may be a button with a wireless symbol on the unit somewhere... press it... wireless should then be enabled...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: my acer aspire one aoa 150 shows a power light on
Your hard drive may have died. and if this is not the case and you can hear the drive spinning, then your monitor power cord from screen to motherboard has failed.
SOURCE: Video controller for Acer One AOA 110
Click here to Acer support
Select Netbook then Acer one, then AOA110,
under driver tab, find VGA driver, click it and download, that is you need for your windows XP
Testimonial: "Many Thanks. I was really a *******, but, believe me, in the internet page of Acer Support I opened, the VGA driver was not listed. Your Help solved my my embarassing problem. Thank you again!"
