Question about HP LaserJet 2820 Printer
  • 37 Answers
You need disassemby the carousel and assemby again , calibrate the carousel by a mark in the left side of then, and the other mark are in plastics of chassis.
Posted on Aug 25, 2009
My rimage perfect image only prints half of a cd
Bad print head,
John Norman
Max Optical llc.
Jan 27, 2012 | Rimage Perfect Image Prism Thermal Printer
Carousel turns prints blank pages
Hi jeff ,
Ok , lets go into the control panel and find printer and devices , click on that icon and then right click on your mouse and go to prop. and make sure the settings are correct , 2nd , reinstall the ink cartridges and see if that works , let me know , and i'll advise futher .................Good luck Roy
Nov 18, 2011 | HP Color LaserJet 2600n Printer
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
The color is faded on the left side of the page printer, what is the possible cause or solution?
From the service manual:
If the light printing is on the left side of the page, the carousel might be dislocated.
Solution: Verify that the print-cartridge carousel drive teeth are aligned correctly. If the teeth are aligned correctly, replace the print-cartridge carousel.
Jun 03, 2009 | HP LaserJet 2840 Printer
Hp 2550 prints only right side of page
printing only the right half of the drum
Nov 28, 2008 | HP LaserJet 2550L Printer
ok typical carousel misalignment
just take a big screwdriver and check for stuck cartridges
Nov 05, 2008 | HP LaserJet 2820 Printer
Printing on right side only
It is the carousel that is dislocated. Check the alignment if it's brooken
Nov 01, 2008 | HP LaserJet 2840 All-In-One Printer
Dislocated carousel
Here a short run down on it:
Common on this type print engine. Your carousel is out of index. Repair requires removing all toner cartridges and printer covers. Big black carousel gears have index marks, one on each side. Trip the solenoid carousel brake at the top left of the rotary drive assembly by lifting the solenoid flap to free manual carousel rotation. Bring the yellow slot to the front, facing you to achieve rough indexing. Look for the two white pins of the white carousel drive gear, one pair on each side. Rotate the carousel to where the two pins, which face inward, are at the bottom. The mark of the carousel gear should be between the two white pins. Chances are it is a tooth or two out of index on one side. To reindex, push the black carousel gear inward and the white drive gear outward to skip a tooth. Recheck, reassembly, and have fun.
Hope that helps you.
Aug 27, 2008 | HP LaserJet 2550L Printer
Left side of page prints blank
Hi there in the paper handling menu check the paper size settings as it maybe as simple as the incorrect paper size has been set in the machine
Hope this works for you
Thanks J
Dec 12, 2007 | HP LaserJet 2820 Printer
HP LaserJet 2820 Printer Logo
239 people viewed this question
Ben Johnson
