Question about Bosch 24 in. SHU43 Built-in Dishwasher
Belt in dishwasher answer
First thanks for the answer. But it seems like it must have come from the dishwasher - maybe its a seal or something? The reason I'm saying this iis that its the exact shade of blue of other rubber parts within he dishwasher. Its about 12 inched long if it was cut and extended.
Ed
  • 67 Answers
IT IS SEAL
Posted on Jan 07, 2009
  • 4,806 Answers
The only thing i think of is that it is part of the door seal, have a look if the door seal has come off
Posted on Jan 06, 2009
My daughter has just bought a 2nd hand dishwasher Indesit IDL 530 it's ok but she has noticed a small leak at the front of the machine. It only seems to leak when machine is standing when it's washing it's...
I would check the rubber seal around the base of the unit on the door.
Make sure its clean as dirt in it can cause a bad seal.
Also check when you open the door to see if water drips out.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Dishwashers
Asko 1375
May be the drainpump that has something stuck into it. Check that
Jun 08, 2008 | Asko 1375 Dishwasher
My GE dishwasher is leaking out the bottom of the front door. Everything seems to be sealed properly. I took the inside of the door off and couldn't find anything obvious. Is it possible to be overflowing...
You most likly need a new bottom door seal. Usually 3 screws down each side of the door and then two screws hold the bottom door seal in place. The bottm door seal can look fine but if its leaking out the bottom front this is the problem 99 % of the time, Unless someone is using dish soap to preclean the dishes or using regular in the dishwasher.
Mar 20, 2010 | GE 24 in. GSD3330C Built-in Dishwasher
Water seems to be leaking into the dishwasher at the end of the cycle the water appears to be clean, so I am wondering about a seal of some kind on the hot water line leaking or whatever. It is a Bosch...
You have a bad water valve. When the unit is off, the valve should seal and the water should not flow. Something has gotten in the valve and is keeping the needle up or the diaphram in the valve has deteriorated. replace the water valve and you will be fine part#425458 @ $16.00
Apr 08, 2009 | Dishwashers
Danby portable dishwasher filter stuck
If it says just pull up then you do just that, it is likely rusted on.
Jul 18, 2017 | Danby 22 in. DDW399 Free-standing...
Simpson Silencio 850 leaks - the water doesn't seem to stop filling. Replaced all seals, but it keeps filling until it leaks and we have to stop it manually.
Hi, I've just purchased a 2nd hand model of your dishwasher. mine actually leaks from the black lining underneath. I've just patched it with some Sellys bathroom sealant. I don't know more about your problem but sounds like it could be something not timing out to stop the water, maybe buy a new 1 :P
Sep 11, 2008 | Dishwashers
BF1620 leaking dishwasher leaking help.
hi,Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Aug 06, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Ariston dishwasher LL64
usual place for a leak is thro the door main seal but it is possible to get a leak thro the dispensor. only way to check is split door, put it to work and see if it leaks in dispensor area
Mar 31, 2007 | Ariston Technologies LI640S Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
125 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
