Question about Samsung HL-S5087W DLP TV
Ge Triton dishwasher will not drain and makes a funny noise.
Hi, I have a GE Triton dishwasher that has had problems draining occasionally. I had a repair man come out about a year ago and he charged us $175.00 for twenty minutes of work. I think he unclogged something. Currently there is about an inch of standing water in the bottom and during the cycle there is this weird crackling noise coming from the bottom front panel. I would like to try and fix this myself if possible. I cannot afford a huge repair bill. Does anyone have any suggestions?
Thanks,
Raelyn
  • 1 more comment
  • Raelyn Frantom
    Raelyn Frantom Jan 06, 2009
    What kind of a long thin wire? Thanks for the advise. I will give it a try...
    Raelyn
  • Raelyn Frantom
    Raelyn Frantom Jan 11, 2009
    Hi I still didn't get the question answered about what type of thin wire to use.. Thanks..
    Raelyn
  • fastillo146 Apr 06, 2009
    dishwasher will run however water will not drain i am trying to locate drain hose to unclog any suggestions
    Genius:
  • 1,199 Answers
Yes!! The crackling noise you hear is small pieces of food stuck spinning around the moter drain....All you have to do is find the drain hose (some are located under the sink of the kitchen) disconnect it from the draining source (not the back of the dishwasher) now run a long thin wire through the drain hose line poke around and pull in and out!! it may take a few tries but its better then a large Bill!! replace hose and hit drain button!!
Please rate response and help keep this site free!
Posted on Jan 06, 2009
GE Triton dishwasher occasionally won't drain all the water..still in bottom of dishwasher or leaks into floor. Not every time!
make sure that a portion of the drain hose was hung higher than the connection to the garbage disposal. hose should not have kinks or twists. if that doesn't work, clean (no clog) or replace drain hose.
Oct 07, 2015 | GE Dishwashers
My GE Triton dishwasher won't drain. How do I de-clog it?
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Apr 24, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
GE Profile Triton Dishwasher wont drain completely
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 14, 2011 | GE Dishwashers
My GE Triton dishwasher won't drain, I need URGENT help !!!!! :(
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Water will not drain out
heatman101
Jan 21, 2011 | GE Dishwashers
GE Triton 24
Hi
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please post back for any further assistance.
Daniel
Jul 23, 2010 | GE Dishwashers
GE TRITON SEEMS TO STOP BEFORE CYCLE IS COMPLETE AND NOT DRAINING
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 04, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE TRITON LX Dishwasher
First check your Drain Cup filter it is just under the lower spray arm you may have something blocking the drain... if its clear check the drain pump... does it run a drain out? can you here it make noise? let me know if this helps ?
Aug 14, 2007 | GE ZBD5900D Dishwasher
Samsung HL-S5087W DLP TV Logo
383 people viewed this question
Henry  Thomas
Henry Thomas
