Question about Toshiba Satellite A100-S8111TD Notebook
Cant connect using any browser,appreciate your help,
Diagnostic test says no error in connection
    Scholar:
  • 91 Answers
1. If you are using a Wireless router, request you disable the wireless connectivity and try to connect the router with the cable directly and enable the Local area network.
2. Move the mouse over the Local Area Network (LAN) in the task bar and see if it is showing any activity.
3. Open command prompt i.e Start->Run->CMD
and type "ping yahoo.com" and if this return the reply then your internet connectivity is correct.
4. Else there could be a problem with your service provider .
If you find the solution useful please rate fixya
Posted on Jan 06, 2009
  • Sandhya Madhavan Jan 06, 2009
    Also please try to check the connection settings of browsers for any Proxy settings.
    All the best .
  • 57 Answers
Make sure your internet connection is hooked up
if its not your internet connection try upgrading your internet
On my 05 Ford mustang v6, my fan only comes on when i turn my AC on and makes a funny noise when I turn the AC on, diagnostic test gave me a code, u1900, what does this mean and how do I fix it?
Where did you pull this code from ? What type scan tool did you use ,or was it a code reader ? Do you know about data communication networks on modern cars ? A U codes indicate a communication problem on the data network .
U1900 CAN Communication Bus Fault-Receive Error Audio Control Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error ABS Module REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error Instrument Cluster REFER to Section 418-00 . U1900 CAN Communication Bus Fault-Receive Error SJB REFER to Section 418-00 . The thing that would make this easier to diagnose would be to have a factory scan tool or a professional grade . Need to know what modules can communicate with scan tool .Honestly ,Don't think you can fix this . Dealer or ASE certified repair shop .Do you know what C.A.N. - controller area network is ? The vehicle has 3 module communications networks:
  • high speed controller area network (CAN)
  • medium speed CAN
  • international standards organization (ISO) 9141 communications network
The diagnostic tool connects to the communications networks through the data link connector (DLC). The DLC allows a diagnostic tool access to diagnose and test the vehicle systems of any module on the communications networks.
All 3 communications networks are connected to the DLC. This makes diagnosis and testing of these systems easier by allowing one diagnostic tool to be able to diagnose and control any module on the 3 communications networks from one common connector. The DLC can be found under the instrument panel between the steering column and the driver door. Which module doesn't communicate with scan tool ?
Symptom Chart Condition Possible Sources Action
  • The anti-lock brake system (ABS) module does not respond to the diagnostic tool
  • Circuit or connection in the high speed controller area network (CAN)
  • ABS module
  • Go To Pinpoint Test A .
  • The audio unit does not respond to the diagnostic tool
  • Circuit or connection in the medium speed controller area network (CAN)
  • Audio unit
  • Go To Pinpoint Test B .
  • Audio unit
  • The instrument cluster does not respond to the diagnostic tool - high speed controller area network (CAN)
  • Circuit or connection in the high speed CAN
  • Instrument cluster
  • Go To Pinpoint Test C .
  • The instrument cluster does not respond to the diagnostic tool - medium speed controller area network (CAN)
  • Circuit or connection in the medium speed CAN
  • Go To Pinpoint Test D .
  • The powertrain control module (PCM) does not respond to the diagnostic tool
  • PCM
  • Go To Pinpoint Test E .
  • The restraint control module (RCM) does not respond to the diagnostic tool
  • Circuit or connection in the international standards organization (ISO) 9141 communications network
  • RCM
  • Go To Pinpoint Test I .
  • The smart junction box (SJB) does not respond to the diagnostic tool
  • SJB
  • Go To Pinpoint Test F .
  • No high speed controller area network (CAN) communication
  • High speed CAN modules
  • Go To Pinpoint Test G .
  • No medium speed controller area network (CAN) communication
  • Medium speed CAN modules
  • Go To Pinpoint Test H .
  • No international standards organization (ISO) 9141 communications network communication
  • Circuit or connection in the ISO 9141 communications network circuit
  • Restraint control module (RCM)
  • No module/network communication - no power to the diagnostic tool
  • Data link connector (DLC) C251
  • Bussed electrical center (BEC) fuse 4 (30A)
  • Smart junction box (SJB) fuse 8 (10A)
  • Circuitry
  • Diagnostic tool
  • Go To Pinpoint Test J .
Apr 11, 2016 | Ford Cars & Trucks
Slow internet connection
A slow Internet connection could be caused by any number of reasons. It may be connection or traffic problem.To increase your internet speed use the following tips given below:
1.clear cookies from your browser
2.Delete unwanted files
3.PC Optimization:
It is important to clean your PC regularly. It means a normal maintenance tasks such as, cleaning the disks, registry repairs and Disk Derangement.
4.If you are using a DSL connection over your landline, make sure that you have high-quality filters in place to get optimum signal speed.
5.Upgrade your modem.
6. Use Updated browser.
7.Consult with your Internet service provider to ensure that your modem is configured correctly.
8.Replace your telephone modem with a fast-access connection such as wave, ISDN, DSL, satellite, a cable modem.
9.Tweak our router settings
10.Install Antivirus Software.
11.Reduce our bandwidth overhead
After, completing this steps, you can check our internet speed whether increase or not using this site ScanMySpeed.com
Nov 14, 2013 | Microsoft Internet Explorer 8
Internet explorer stopped working
Diagnose Connection Problems With Internet Explorer
Internet connection and network errors can be frustrating and confusing to a casual computer user.
However, Internet Explorer provides a diagnostics tool to help identify and even repair the most common network issues.
This tool is simple to use, organized in steps, and can help get a computer back up and running quickly.
Open Internet Explorer and click on the "Tools" button in the control bar at the top of the window. From the "Tools" menu, select "Diagnose Connection Problems."
A window will appear, displaying the start page of the diagnostics tool.
Follow the instructions to determine the cause of the connection error.
The diagnostics tool will ask a series of multiple-choice questions about the connection problem you are experiencing.
Close all programs and restart the computer.
If you continue to receive an error when attempting to connect to the Internet, check that all cables and power-supply cords for the computer, modem and/or router are properly connected. Then, run the diagnostic tool again.
Call your Internet service provider's technical support phone number if you cannot resolve the error with the diagnostics tool.
The Internet Explorer diagnostics tool cannot repair or reset malfunctioning or failing hardware like modems and routers.
windowsxp using networking expert russel diagnostics mspx
http://www.microsoft.com/windowsxp/using/networking/expert/russel_diagnostics.mspx
Support for Windows Internet Explorer 6, 7, 8, and 9
http://support.microsoft.com/ph/13418 - tab0
Internet crashing
If your Internet Explorer keeps randomly crashing (closing by itself), there may be an add-on or temporary page disrupting the connection.
Every time you browse the web, Internet Explorer keeps track of the websites you visit.
It keeps these pages, along with cookie trackers, in the "Temporary Browsing History" folder. Some websites cause Internet Explorer to crash.
Open the Internet Explorer browser. Go to "Tools > Delete Browsing History."
Hit "Delete All."
Check off the box that says "Also delete files and settings stored by add-ons."
Hit "OK."
Close and reopen the browser.
Disable Add-Ons
Go to "Start > Search."
Type "Internet Explorer" and hit "Enter."
The computer will search for any files with this label.
Double-click on the file that says "Internet Explorer (No Add-Ons)."
This will allow you to browse in IE without any additional plug-ins or add-ons that might be causing the browser to crash.
Reset Internet Explorer
Open the IE browser.
Go to "Tools > Internet Options."
Hit "Advanced." Click on "Reset" and then hit "Enter."
You might have to many programs trying to or accessing your computer or the internet at the same time or a virus
Scroll to bottom toolbar (bottom of screen) right click select task manager applications and processes to see you what's running and ticking over
if you see anything you don't need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
don't need to be running select end now and users you will see who is using your computer
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
Aug 03, 2013 | Computers & Internet
My internet keeps giving me a internet connection error
Step 1:
You might have some unwanted browser interference
Internet connection and network errors can be frustrating and confusing to a casual computer user. However, Internet Explorer provides a diagnostics tool to help identify and even repair the most common network issues. This tool is simple to use, organized in steps, and can help get a computer back up and running quickly.
Open Internet Explorer and click on the "Tools" button in the control bar at the top of the window. From the "Tools" menu, select "Diagnose Connection Problems." A window will appear, displaying the start page of the diagnostics tool. Follow the instructions to determine the cause of the connection error. The diagnostics tool will ask a series of multiple-choice questions about the connection problem you are experiencing. Close all programs and restart the computer. If you continue to receive an error when attempting to connect to the Internet, check that all cables and power-supply cords for the computer, modem and/or router are properly connected. Then, run the diagnostic tool again. Call your Internet service provider's technical support phone number if you cannot resolve the error with the diagnostics tool. The Internet Explorer diagnostics tool cannot repair or reset malfunctioning or failing hardware like modems and routers.
windowsxp using networking expert russel diagnostics mspx http://www.microsoft.com/windowsxp/using/networking/expert/russel_diagnostics.mspx Support for Windows Internet Explorer 6, 7, 8, and 9 http://support.microsoft.com/ph/13418 - tab0
Mar 13, 2013 | Computers & Internet
I keep getting 404 erre
Which browser are you using and is you wireless connection constant?Also resetting your modem and router may help regain a good surfing connection as well.Let me know...Lee
Nov 27, 2011 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Hi I just bought an HP Pavilion DV6-3138TX Notebook which runs on Windows 7. Most websites open except for Facebook, which takes a long time, never opens as it says "ERROR The requested URL could...
Hi Kathryn, it may just be that facebook's servers are overloaded or some wider-network issue so your PC cant establish a connection with facebooks servers. Perhaps you can just wait for a few hours or try again tomorrow to see if there are any changes.
In the meantime, try downloading any updates for your browser (I suggest using Mozilla Firefox or Google Chrome over Internet Explorer) and then try again. It may just be a browser issue that gets in an endless loop trying to load some parts of Facebook's page, and an update of the browser should fix the problem.
Jan 14, 2011 | HP Pavilion DV5234US Notebook Laptop
Cant open mirosoft website
When you open your browser and it cannot load the web page that means there is no internet connection... if there is... then the connection is not stable..
Try this, could help you stabilize your connection...On the top of your web browser, on the File menu , uncheck the "Work Offline"...........If you are using a wireless internet connection.. disable the firewall setting of your windows so that windows will allow the connection of internet and will not be strict...If you are using a broadband router make sure it is receiving high signal... and make sure to keep away the unit 1 meter from any live wiring or wall outlet..
I hope that solve your connection issues..
Much appreciated if you rate this help..thanks..
May 24, 2010 | Toshiba Satellite P35-S605 Notebook
My wireless connection has disappeared , had wireless on my laptop and now it is gone and cant go to http:// 192 connection says my browser needs adjusting maybe.
A "Diagnostics" can identify the cause of the problem, or (errors) and try to correct, the "Internet" connection. Go, to: Control Panel, select "Network and Internet." Select, (“view network and task status”),choose a task”, to performed, from the (left) pane. You can start a quick diagnostic by clicking on the connection "diagram", Computer---WNC---Internet. “You can (setup) personal computer, internet settings.” I hope this Fix it.
Jan 21, 2010 | Toshiba Laptop Computer Battery PA2510,...
Ipod wont connect to computer or itunes
slide the hold button on and off a couple of times and then let it rest in off position and press and hold menu and centre buttons till a silver apple logo comes.the connect to system and it should be detected by itunes in recovery mode.restore and you're done.
Aug 22, 2009 | Apple iPod nano 3rd Generation
Lan connection has disappeared from network but wireless works
Have you run the Dell Diagnostics test? reboot the computer and hit the F12 key, scroll down to the diagnostic option and run the test, it will check hardware and memory etc.
Apr 04, 2009 | Dell Latitude D600 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
