Question about RCA RT2380 Home Theatre System System
RCA surround sound system probs
This system, after being left on over night, will not turn on anymore.  I unpluged it for a whole day, plugged it back in, the red light turns on (saying it has power) when you press the power button, the red light goes out and you can hear a click (which is normal), then nothing happens.
I left it alone for a few months, and it started working again.  So I hooked it back up.  The other day, I used it again, and forgot to turn it off.  Guess what happend....... it doesn't work anymore.  Its doing the same thing again.   Im at witts end with this system.  Im pretty electroniclly inclined, so I know that its not from wireing or anything.  Im just confused on whats going on.  Any answers to this?
  • Kevin rice May 27, 2013
    I have an RCA home theatre system rt2380 the volume will not go up or down manually or by remote.the volume only goes up to 40 but it is stuck on 52 and won't move can someone please help me out?
    I have a RCA home theatre system rt2380 my volume will not go up or down manually or by remote mt volume only goes to 40 but for some reason it is stuck on 52 and will not move can someone please help me out
    Genius:
  • 1,175 Answers
HI...
MOst likely a component connection that opens" no circuit" when heated then "might" connect again at some future date..Maybe at the return of Jesus or something.
It's not something that a consumer can fix.
Take it to a tv /stereo repair shop and have them look for bad solder joints in the amplifier section
Posted on May 01, 2009
    New Friend:
  • 111 Answers
Power supply problem.can you open the circuit board.
Posted on Jan 06, 2009
Rca 40LA45RQ . power light comes on but nothing else (no picture, sound, menu). Unplugging and plugging back in does not work (anymore).
Mine is doing the same thing. Drives me crazy. Usually turns on in the morning, but not at the end of the day. Makes no sense.
Sep 24, 2013 | RCA 40" Class LCD 1080p Widescreen HDTV,...
Sorround sound switchboard lit up and quit working.
If the fan is making weird noises there is either something wrong with the bearing or it has ingested something.
Maybe you could look, listen closely and determine which it is. If it's foreign matter you may be able to extract or vacuum it out. If it's just bearing noise, you have to decide how bothersome it is and if a shop visit is justified. A clog is BAD because the fan is protecting the unit from high temperatures.
Feb 17, 2010 | RCA RTD300 System
I've bought a panasonic sound surround dvd player and want to link it to a sky+ box and tv so that sky will play in sound surround. Can you advise on the wiring configuration please?
look at the back of your tv does it have a audio out RCA jack?
it should do plug in the surround sound into that using RCA cables
if your tv does not have audio out RCA jack then you can
get a adapter which makes scart connectors turn into RCA jacks get that off ebay
plug the yellow line to the tv and connect the red and white to suround sound
but with this there are a few problems sound will only come out when surround sound is turned on and skys sound will never play out the tv
if you switch to a PS3 or something it will not play suround sound
yuo best option is the RCA plugs in the back of the tv
because you have not written the model number of the tv or the suround sound i cant help any further
Jan 12, 2010 | Panasonic Home Theater System System
TV turns off when you change the channel
sounds like a power fault, prob just weak capacitors if you can change them it would not cost a lot to replace them, when you change channel it draws more power and if its at its limit it will turn off as the capacitors cannot take it. few £'s or $s to get the replacement capacitors, you will probably see the blown capacitors on the power board as the will not have flat tops they will be rounded, change them same for same i.e 16v 330 for same 105c type would be best. it will say this on the capacitor.
May 27, 2017 | RCA TruFlat 27F520T 27" TV
Problem with Surround Sound when watching TV
No wonder you havent gotten no reply your listed under wrong tv
May 06, 2008 | RCA D52W19 52" Rear Projection Television
Bose CD for Surround Sound System
First suggestion by Bose was to unplug the power cord for about 30 minutes and then plug it back and hit the Eject button...didn't work. Second suggestion was to unplug the power, tilt the unit up onto its left side and then "whack" the bottom of the left side a couple of good whacks. Worked fine and cassette would then eject.
Apr 20, 2008 | Bose 683-0127FB CD Shelf System
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
RCA RTD215 surround sound
I could only get surround sound for DVD, NOT cable/TV--regular audio jacks only give stereo for cable/tv, NOT surround sound. Very disappointing. Any thoughts/solutions for how to get surround sound? Cable box has digital output, but no input on the rtd 315, any help available? THX
Nov 01, 2007 | Audio Players & Recorders
RCA RT2380 Home Theatre System System Logo
477 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
