Question about Sharp AR-5320 Black and White Copier
SHRP AR-235 ERROR CODE F5-02
When I turned Copier On the scanner bulb light comes on for a few seconds than it goes off, Than I got ERROR F5-02,
Thank you.
  • Beachsidepad Jan 16, 2009
    We have the same problem, replaced the bulb twice and then the little board that goes along with it...and still get the error.
  • 26 Answers
"F5-02 : Exposure lamp blown"
Posted on Jan 07, 2009
  • 1 more comment
  • Vasile Bot Jul 12, 2013
    Thank you,becouse is a old copy maschine ,can you help me to
    found a part exposure lamp flat cable? Thank You!
  • idnoblenet1 Aug 07, 2017
    The problem is in the camera in the optics there are three screws you need to use your own ingenuity to adjust the screws respectively and test that's all.
    Problem Solver:
  • 3 Answers
Check scanner flat cable,exposure lamp,exposure lamp section,i hope it should be change flat cable,
Posted on Sep 27, 2011
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Our office has a Sharp AR-235 Digital Imager copy machine and a L1-00 error message has been popping up for the past few months. Just wondering what the problem is and how we can fix it? We had a...
L1-00 is the detection of the scanner in the home position.
Your scan rails may be dirty needing cleaned, maybe add some lubricant.
The scan home sensor may be intermittent, just not seeing the scanner head in the proper position.
You can try blowing it out with canned air, I am sure he cleaned that.
It is possible you have an intermittent connection between the scanner and processor board or a bad processor board.
If it is an off and on issue I would suspect the home sensor . Most of the time that problem is one where you go in and the issue is very obvious. Every now and then you have one that is difficult to nail down and can be a headache.
If you remove the glass and you dont find the scan assembly is hitting anything or is difficult to slide in certain spots, have him replace the scan home sensor and reseat all the connectors to the MCU board. The MCU is the Main Control Unit. Just a term used to describe the machine processing unit.
Feb 23, 2011 | Sharp AR-235 Copier
ERROR F5-02 call for service code AR 235 MODEL
F5-02 = Copy Lamp Lighting Abnormality.
Possibilities are blown copy lamp, failure of lamp harness (cable) or the MCU board.
You may need to replace either the copy lamp unit or the MCU board.
To check the operation of the lamp..
Enter service mode 5-03
#, [interrup],C,[interrupt],5,[copy button],03,[start button].
The lamp should light up for a few seconds.
Hope this helps.
Jan 15, 2011 | Sharp AR-235 Copier
SHARP-235, F5-02 CALL FOR SERVICE CODE
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Sep 04, 2010 | Sharp AR-235 Copier
Sharp AR 235, output light
You have to change the Developer in the developing unit. code is: AR271D
This procedure must be done by a copier tech.
Feb 15, 2010 | Sharp AR-235 Copier
Sharp AR 235 error code E1-11
Abnormality on the IMC board.
Try resetting by pressing # / interrupt / c / interrupt.
punch 14 and ok / enter.
restart your copier.
if it doesn't work you will need a tech.
Jun 17, 2009 | Sharp AR-235 Copier
Sharp AR 235
Did you clear the code? It's been a while since I worked on one of these but there is a diagnostic mode you need to go into. Something like:
C Interrupt 0 Interrupt
at that point the machine clicks and asks you for a test command number. Enter 14 and press the copy button. That should reset the code. If not try 15.
Jan 19, 2009 | Sharp AR-235 Copier
Sharp AR-5320 Black and White Copier Logo
925 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
