Question about SanDisk Sansa e250 MP3 Player
Sansa help I got my sansa e250r last Christmas and now when i plug it into the computer the icon doen'st show up anymore. Please HELP!
  • 2 more comments
  • Anonymous Feb 23, 2008
    my computer dont see the device and the usb port
  • techwimp Feb 28, 2008
    My new Sansa 2GB Clips worked fine at first. I loaded music on one and audiobooks on the other using a Windows PC. Then, when visiting a friend, I recharged them on his Mac. The display seemed to show that the battery was recharging properly. However, now when I turn them on the screen and dial light up but the dial buttons do not work. When I connect via USB port to a PC, Windows does not recognize the device. All I can do is turn it off. I tried the 15 sec reset suggested in the manual, but this does not help. Is it possible to do a 'hard' reset by pushing some combination of buttons. Please help. Thanks tgerhart@caregroup.harvard.edu
  • Anonymous Mar 07, 2009
    same prob.
  • dlog81 Mar 07, 2009
    just bought e250. I use itunes to store music on pc. computer does not recognise e250 so cannot transfer music across
Change the USB mode by going onto your MP3 and go to settings change it from MTB to the other mode then try to coneect it again.
Posted on May 29, 2007
I just got my sansa and it wont let me down load the Best Buy Digital music store it says it cant becouse i have somthing runing but i dont
Posted on Oct 05, 2008
Device wasn't recognized by pc pls give some suggestions
Posted on Aug 26, 2008
My sansa e260 cannot be reconized by any computer when i connect it please help i want to put new songs on it
Posted on Jan 16, 2008
Usb crod can't connect to the pc
Posted on Jan 03, 2008
Also is your usb port working ok ? try plugging some thing else in it to see if that works.You may have picked up a bug with some downloads recently...Run a scan with your anti virus software.You may have to reset your computer from that date.
Posted on May 25, 2007
A Firmware upgrade may help.Connect it to the computer with usb and log onto the Sandisk website and follow the instructions,worth a try!!! or e mail them first to see what they have to say.
Posted on Oct 03, 2009
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
No installation CD for Sansa e250R
Hi
You can download and install the drivers from this link---
Sansa drivers
Sansa rhapasody player
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Thanks
Rylee
Mar 03, 2009 | BoxWave Corporation SanDisk Sansa e250R...
My Sandisk Sansa e250r keeps freezing up....
I called sansa and got this info on how to format the sansa and restore it back to default
This helped me to detect the device and be able to put songs on it.
Turn off device
put hold key on
press and hold mic key while pluggin in the device to pc
open sansa icon in my computer
Up on top of my computer window click tools then folder options and click view tab then uncheck hide extension for known file types.
Now click file new and choose text document then change the name from New Text Document.txt to sansa.fmt and click enter. It will ask you if you want to change the extention and you need to click yes.
Now unplug your sansa from the pc and this will format your whole mp3 player.
You will lose all your date but your sansa will be detected and working.
Once it is done then turn off your device and plug it in while its off.
It should show up in my documents now. The first drive is your hd on the device and the second one is for the extra micro disk.
Oh and another tip is to click show hidden files so that you can see the music folder.
This way you can just drag and drop without having to use windows media player or Rhapsody.
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
Sansa help
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Nov 27, 2007 | SanDisk Sansa m250 MP3 Player
4 GB micro sd and the Sandisk Sansa e250R...
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my Sansa Sandisk e250R
To fix it, format your Sansa. I had the exact problem. Plug it in, then in "My Computer" right click its icon and hit format. Do not select quick format. Then it will be fixed.
Apr 27, 2007 | SanDisk Sansa e250 MP3 Player
What music file?
Use Windows Media Player to view
Jan 26, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
916 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
