Question about HP Compaq Presario V2000 Notebook
The bass it super low
It sound like no bass at all
    Problem Solver:
  • 19 Answers
Normally the laptop sound is crappy.and if you force the bass by changing the EQ it wont be a nice sound.
Posted on Jan 06, 2009
Why am i getting sound out of my subwoofers but no bass
Check your strings on your amp they have low pass and high pass filters do some research online on those i cant remember which one it is i think its the low pass that only let low frequency sounds come out of the subwoofer i think mine is set at 110 to 120. Or you could try head unit settings
Aug 04, 2014 | Kicker Car Audio & Video
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
No sound plugged in with low green light on and connected properly. This unit worked perfectly for 3 years never an issue, now there is only a low hum, with no response to the input.
If the fuse has gone you would get no power at all. Subwoofers are basiacally mono amps that only put out bass tones. So when you get no sound the likely cause is the semiconductor that does most of the work that amplifies the signal. It could be an IC amp or FET or a Transistor, it could have an heatsink on it. But I would look to that for the cause of your problem.
Dec 16, 2012 | Sunfire Super Junior Subwoofer
I have a problem with my z-5500! the bass is really bad, on all the effects. my friend has the same pare of speakers han his bass is really good. what should i do???
Always make sure that your computer settings for audio are checked and set accordingly and that all the equlizers and audio programs that are installed and controlling your audio sound output are accounted for and adjusted properly.
Feb 07, 2012 | Logitech Z-5500 Computer Speakers
Is it possible to hook up 2-6x9 and 2-12in.subs to the 7540a and still pack a nice punch
yes it is however the hookup for it requires something a bit unorthodox
you have 4 outputs (bridgeable)
channel 1 and 2 must be bridged (to lower the ohms) then connected to the 2 6X9 in Parallel..
this must then be set to the high pass frequency (eliminates bass)
lower all the settings as low as possible then turn them up slightly to increase volume to a level where its the hardest and clean sounding..lower volume after
this eliminates the bass and keeps the 6x9 pushing your mid range and high range frequency
now you have 2 channels remaining,, set 3 and 4 to low pass and connect each 12" to an individual channel. (this keeps the bass and ohms high so you will get a clean bass to match with mids and high's. Dont set or bridge for a low bass as it will jam out the 6x9 and your music will sound terrible.
so there u have a simple hookup that will work and keep you sounding clean. remember not to raise the volume on the 6X9 too much as you will blow them..
Mar 29, 2011 | Infinity 7540A Car Audio Amplifier
What r the best freqency settings for my jvc rx-701v super a home stereo receiver. I like BASS
There isn't any "best" setting. It's whatever sounds good to you. So if you like bass, crank it up and enjoy.
Oct 15, 2010 | Audio Players & Recorders
How to mount a bandpass sub
usually you will get the best sound with the box mounted approximately 3" away from rear of trunk with speaker facing toward the rear of trunk if it is a single speaker enclosure you want to do the same just offset it to one side of the trunk corners always amplify sound however just so you know 10's are not really made for low bass they usually have more of a hard hitting pound instead of a low rumble usually 12's will give you the low bass better and it also depends on what kind of box a vented box would be best for low bass sealed box gives you tighter bass but you need more power ported is good for low bass but gets sloppy when loud and a bandpass is used for loud hard hitting bass
Feb 27, 2010 | Car Audio & Video
TECHNICS SUPER BASS, DOUBLE BASS AND TRIPLE AMPLIFIER
Have you checked all circuit boards for good solder connections.
Also if the boards had been wet from anything, you might clean the boards and resolder all connections specially in the power supply and audio section.
Let me know.
Jan 26, 2009 | Technics SUV500 2-Channel Amplifier
Poor sound
Sit low Bass @+3 / Mid@ 0 / Hi+10
Add SubWoofer with separate Amp and use low pass filter @78hz cuttoff.
It's a cheap unit -don't expect High Fidelity & a warm EQ<
Nov 19, 2008 | Sony CDX-R3300 CD Player
HP Compaq Presario V2000 Notebook Logo
209 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
