Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson Animal motor is running, beater bar is turning but very little if any suction. No suction from hose either. The inside canister is filling and moving, so there is some dirt being sucked in there. I have thoroughly cleaned all filters but not sure what is causing the problem. Any ideas?
  • 15,935 Answers
Obstruction in the hose?
Your vac has developed a hairball possibly.... when a piece of flexible media ie.... cardboard, plastic etc... gets lodged in the hose, and begins collecting hair & dust to the point it no longer has enough draft to pull debris from the floor.
Here is a video that you may find useful
http://video.aol.com/video-detail/dyson-not-picking-up-dirt-no-suction-how-to-repair/2334249387
PS I Thought DYSONS were guranteed to NOT lose suction? What a RIP!
Posted on Jan 06, 2009
  • blueextc3221
    blueextc3221 Jan 06, 2009
    Despite the claims that the Dyson vacuum does not lose suctions, I've had occasions where mine has lost suction even after I've emptied the canister. What I found is that for the piece inside the canister that gets emptied, there are hundreds of tiny holes. If you vacuum up lint of the right (or wrong) size, it can lead to these holes getting clogged.
    There is an easy fix though. Just get a short metal brush and have at these holes. It knocks out the lint that gets stuck in them, and you'll get full suction on your Dyson vacuum again.
Dyson canister DC39 - beater bar won't spin once it touches the floor
Some models have the beater bar driven by the airflow from the vacuum rather than a small motor. It takes a lot of suction to turn the brush roll. Make sure there are no restrictions which will reduce the airflow and suction. Replacing the filters may help if the vacuum motor still has adequate suction.
Sep 17, 2017 | Dyson Vacuums
How do I fix the suction on my Dyson vacuum?
check the pipe is saying that is clogged with something who knows lots clock that pipe make sure all pipes from your vacuum is is unstuck are clogged.
Nov 29, 2014 | Dyson DC65 Animal Complete Bagless Upright...
Fault finding
Have you accidentally switched off the beater bar via the dial on the head? Some models have a 'hard floors' and a 'carpets' setting (which disengages/engages the beater bar).
Jul 06, 2014 | Dyson Vacuums
Power only comes on when vacuum is not upright
Power or beater bar? Beater bar is supposed to turn off when upright, but suction motor should still run.
Nov 14, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction for rugs but the hose works fine. Removed the canister and suction is at that point
Remove the base plate and beater bar. Clean the suction cavity behind the beater bar. That's where they almost always plug up.
--W.D--
Aug 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My dyson animal is hard to push on carpet - the beater bar is still operational. When I turn off the beater bar and run the vacuum on hardwood the beater bar stops moving, but it still ''rolls'' on the...
If suction is not what it was, check all of your hoses and connections for vacuum leaks. And the beater roll should always be turning - check out the belt for slippage.
Sep 20, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction
so the red hose isn't connected to a part on the vaccum so like it is connected to the connester but not to an opening just above the beater bar, this is the only idea i can supply you with. good luck, maybe i got lucky and helped you out.
Jun 12, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
498 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
