Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
WM 0642HW Drain Pump?
I have gone through the recommended steps: No blocks/kinks in drain hose. No debris in impellar. Impellar not loose. Connectors connected. How do I know if it is the drain pump? If it is drain pump how do I replace it/remove old? HELP I'M DROWNING IN DIRTY CLOTHES! Happy New Year 2009 - hope it gets better!
  • 1 more comment
  • graleigh Jan 06, 2009
    Same problem Model # WM0001HTMA
  • Burb blues Jan 13, 2009
    Washer won't drain and filter/hose are clean. I want to remove the drain pump but don't know how. Any suggestions?
  • shelleyZ Jan 18, 2009
    I have same problem and its out of warrenty but it is not that old?
    Problem Solver:
  • 14 Answers
I have seen these drain pumps fail before, sand builds up behind drain pump impeller and prevents the impeller from spinning fast enough to drain machine. you will need to replace this pump but it is not easy tadk, I recommend you call for service to authorized LG servicer that is factory trained. These machines are delicate and need professional service, call Geek Squad they will service it (yes they service appliances). Since Best Buy sells so many LG machines, they have great experience with this. Try calling Sears as well, they have training on same product.
Posted on Jan 20, 2009
Lg wm2455h is not draining: i have taken out and cleaned pump filter and that did not correct the problem. I place the machine on the drain and spin cycle and i can hear the pump hum, but doesnt drain. ...
most likely you have a bad pump and it needs to be changed out or something is still stuck in the impellar,stick your finger into the pump and feel around the impellar,i've found under bra metal pieces stuck in there,elastics and string rapped around it and coins lodged in between the impellar and wall of the pump,if the pump is bad or something is stopping the impellar from spinning it will hum,power is going to the pump but the motor isn't spinning.
Nov 12, 2011 | Washing Machines
Dish washer will not drain after the cycle is complete. There is about 2 inches of water remaining at the bottom of the dishwasher.
You may need to remove the drain hose from the bottom of your sink,put it in a bucket and try to drain your dishwasher.If this still does not work and you have a wet dry shop vac you can use it to drain the water from the hose this will also allow you to check for anything restricting the flow of water thourgh the hose.Once the water is gone you may need to remove the dishwasher from the cabinet and check the drain pump for something that is stoping the impellar wheel from turning.If there is nothing stopping the impellar thenyou will need to replace the drain pump.
I hope this hepls with your problems good luck.
Oct 08, 2011 | Dishwashers
Hello all I have been getting the F21 error code (seems to be a popular error) I cleand the drain on the pump as I was cleaning debris out i noticed the motor impellar was cracked so I replaced it. ...
My WAG would be yes, something is still in the drain line. Especially since enough debris has been through it to crack your impellar.
Have you tried running a guitar string up to see if you can dislodge any blocks.
Jun 09, 2011 | Kenmore Washing Machines
Error code F 35
F35 is a slow drain error check for kinks or cloggs in the drain line. Also check that the pump is not clogged and while checking the pump check the impellar on the pump that no impellar blades are missing as well. broken fins on the impellar or if the impellar is not spining would give you the same fault pump error if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 11, 2011 | Kenmore Washing Machines
The water is not draining from the dishwasher
Check to see if debris is stuck in the drain pump or impellar is blocked.Verify pump is running by putting into drain cycle.
Feb 02, 2011 | Dishwashers
When washing towels the washer doesn't drain all the water out causing the washer to jump around.
i would check the drain pump assembly and the hoses attached just to make sure that there is no debri that could be obstructing the drain... also make sure the impellar in the pump is free spinning and not hanging up... good luck to you .
Jan 30, 2011 | GE Washing Machines
I have a lg washer that sometimes it drains and other times it doesn't. the filter is clean and when it doesn't drain it makes no noise like it is tied up. it just sits silent. it fails to pump at...
Have you removed the hoses to the drain pump and looked for any kind of obstructions.You will need to make sure there is nothing blocking or slowing the impellar wheel.
Dec 29, 2010 | LG WM-2277HW Front Load Washer
F02 light flashing during every rinse
If you have noticed water isnt draining, that almost certainly will be the problem. Depending where in the program the problem starts so will the different error codes appear. Remove pump and clean the contents at the impellar., then retry.
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The water isn't draining after a cycle, so clothes are very wet coming out of machine
check the drain pump there could be something that is blocking the pump from turning.use a sshop vac and attach it to the end of the drain hose if the water comes out easy then there is something small stopping the impellar wheel from turning.if it doe not come out easy it could be a piece of clothing blocking it or a bad drain pump.the lat possible problem is the main cotrol board has gone bad
Sep 17, 2009 | Washing Machines
Water will not drain form tub
does it sound like it wants to drain?
if the pump does run. you would have to remove the pump and clean it out. its possible that the impellars on the pump could be broken, meaning you would need a new pump. but usually its change, or small objects jammed in the pump impellar.
Jun 18, 2009 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
175 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
