Question about KitchenAid KSRS25IL Side by Side Refrigerator
Kitchenaid Superba Model# KSRS25QDWH01 For some reason my ice maker is overfilling with water. I have adjusted the "adjustment screw" and it is still overflowing... Does anyone have any other suggestions? Thanks
    Scholar:
  • 110 Answers
You may have a high water pressure issue or just have a water inlet vavle that is failing not completely closing after the im stops calling for water. try turning the water on/off vavle all the way off then openit just 1/4 of the way open if this solves the issue its high water pressure if it doesn't the water vavle is failing and if it is not dealt with it will damage the icemaker
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Jun 01, 2008
Kscs25fkss00 ice maker leaking when making ice, water seems to flow over the top
Did you check to see if the ice maker has been changed prior to this problem and if so was it a correct replacement for this refer by model #? Has the module been changed? Again, correct part ? Is the water adjustment screw on the module incorrectly set ? The last question to your problem is, has hard water conditions caused the mold to become rough due to the coating separating from the metal ? This causes the water to not flow correctly into the total mold . Hope this helps a little.
Oct 12, 2013 | KitchenAid Superba Architect KSCS25INSS...
Water overfilling the freeze tray on Whirlpool conquest ice maker
The overfilling is most likely caused by defective water control valve on the ice maker side. The replacement for your model is a=> W10408179 Water Inlet Valve
The water fill adjustment can be found in the Ice Maker Troubleshooting Service Manual These settings can cause too little or too much by turning the set screw so use caution. I will be here should you have questions or comments, Thanks Sea Breeze
Mar 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker is overflowing and causing icicles in Kitchenaid KSRS25IHSS02 side by side refrigerator. Trying to find location of water flow adjustment set screw.
The adjustment screw is under the cover on the front of the icemaker...it is only a very small adjustment and by adjusting it very likely it will have no bearing on stopping the icicles from forming on the i/m but instead what the problem is,is the water inlet valve is not fully closing. This tip i wrote covers the problem with the water valve and why its causing icicles in the freezer.
http://www1.fixya.com/support/r10343350-icemaker_drips_causing_all_ice_freeze
GENE
Sep 28, 2011 | KitchenAid Superba Architect KSCS25INSS...
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
I can get water out of door but water is not filling ice cube tray.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If you get water the ice maker is the problem.
Jul 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water overflowing in ice maker.
I just replace my kitchenaid icemaker. My model is 4317943. And it comes with a sheet of menu. I scan a portion and hope it will help.
Apr 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
May 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
205 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
