Question about Crimestopper RS1505DP CoolStart(TM) FM/FM Remote Start System with Two 5-Bu
Remote wont make truck start?
I have a crime stopper rs 900 remote engine starter. it worked great a couple days ago but now when i hit the start button the parking lights blink and theres a really short beep and thats all it does now? the remote also has power lock buttons which still work just wont make truck start?
  • Anonymous Feb 17, 2009
    i have the same problem doesnt help
    Problem Solver:
  • 9 Answers
Ok this happend to me once take the key and stick it into the ignition and turn it 8 times only turn it untill the lights go on DO NOT START THE ENGINE EACH TIME after this try it again
Posted on Jan 06, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
1tx ezze start remote
Either hit lock then the start button once if that doesnt work Hit lock and then start button 2x.
Nov 11, 2013 | 2-Way Remote Starter
I have a crime stoppers remote start/alarm when I use the unlock button it only unlocks the doors, it does not disarm the alarm. How do I disarm the alarm?
You need to hook up the disarm wire also and depend of what car you're working on, it will disarm when you unlock the car.
Jan 13, 2011 | 2-Way Remote Starter
How do you make the doors not lock when you start your car with a crime stopper remote start
That is a function of the security system. Are you sure you want remote start without locking the doors? I don't believe you can change the programming of that function but the user manual for your alarm should explain how if it can by done.
May 11, 2010 | 2-Way Remote Starter
I bought a 2004 bonneville with coolstart remote the number looks like chx433tx i can not read any of the buttons please help, a diagram of the remote would be great and what it will do thanks much
Hi There
I've checked the Crime stopper archives without finding that model.
It's possible that the manual for it is bundled in with the unit model number.
Click herefor the Crime Stopper transmitter ID page. Choose from the selection atthe top that best describes your unit (2 button, 3 button, etc).
Then a picture gallery is posted to help you identify it and the model it belongs to.
After that go to the support/manuals section to find the operator manual. That will contain the procedures you need.
I hope you find this information to be very helpful in solving your problem
Best regards
Mike
Nov 02, 2009 | 2-Way Remote Starter
I have a Crimestopper rs-3. I have had 2 instances where my car won't start with the remote or the key. This was just installed 2 weeks ago. Had a tow truck come to tow it to a local garage. The driver...
What type of vehicle is it installed in? Does it crank with the key and not start or does it not do anything? There could be several problems, ie. if a bypass was used to bypass a factory anti theft it could be malfunctioning, if your crimestopper has security features enabled that could prevent it from starting even with the key. (This is most likely if the driver was able to start it by pressing the valet switch). Or there could be a loose connection in the ignition harness. Either way, I would highly recommend taking back to where it was installed and heve them go over it.
Hope this helps.
Oct 29, 2009 | Crimestopper RS1505DP CoolStart(TM) FM/FM...
HOW DOES THE REMOTE OPERATE
Hi There,
Since I don't have your model#, I can't really give you specifics. I realize the model# may not be easily accessible and Crime Stopper markets quite a few different models.
So let's take a different route. Click here for the Crime Stopper tech page. There you can find operating manuals, FAQ's and a whole lot more. Good stuff.
Check accessories for the remotes also.
Best regards
Mike
Oct 19, 2009 | 2-Way Remote Starter
Cool Start model CS34-II TX manual
the problem with this remote is that it is used for a bunch of different models you have to look under the dash and get your unit model number and then check the crime stopper manuals for that units number you do this at www.crimestopper.com under support tab click on manuals and manuals again and then choose the model number you found under your dash
Oct 17, 2009 | 2-Way Remote Starter
My crime stopper remoye start will not work the
try programing the remote again by going to www.crimestopper.com and to the support tab choosing manuals and manuals again with the model number from the unit under your dash find the manual for that model for any other question you can contact their tech support at 800.998.6880 ext 210
Oct 03, 2009 | 2-Way Remote Starter
Rs 810 crimestopper coolstart remote engine starter
Could be one of several things, and depends on the way it was installed. IIRC, those systems can either detect an increase in voltage when the car starts, or a preprogrammed RPM signal. If you have access to the owners manual, see if you can reprogram the RPM ro voltage threshold yourself. That should see an end to the overcranking......
Dec 14, 2008 | 2-Way Remote Starter
Crimestopper RS1505DP CoolStart(TM) FM/FM Remote Start System with Two 5-Bu Logo
687 people viewed this question
Top Crime Stopper Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
John
John
Frank Mangiapane
Level 1 Expert
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
