Question about GE Nautilus 24" Built-in Dishwasher
The dishwasher wont drain after a cycle - GE Nautilus 24" Built-in Dishwasher
  • 3 more comments
  • Anonymous Jan 07, 2009
    No it is just sitting in the bottom of the dishwasher. I pulled the drain tube and got all the water out but it is still not draining on its own.
  • lezli Jan 07, 2009
    I have the same dishwasher and the exact same problem Drain is not clogged.
  • Anonymous Jan 11, 2009
    dishwasher will not drain after cycle
  • aswainiac Jan 17, 2009
    My dishwasher will not drain either ?? The bottom is full and it overflowed into the kitchen all over the tile. What do I do ?
  • erica graber May 11, 2010
    Is it comming out ofg the air gap in the sink? is the sink flooding when dishwasher is draining?
The pump, if you take stuff apart you could shut the water off to the unit, hot wire or jump the switch that tells the dishwasher the door is closed and then you can see if it is working
Posted on Jan 17, 2009
Check to see that your energy option switch is good. You can also try and manually drain the tank from underneath.
Posted on Jan 14, 2009
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Dishwasher was not draining. I cleaned out everything and now it wont start
I have the same problem with another Kitchenaid model. I've had better results at keeping the water drained by running two back to back water saver cycles than running a full pots and pans cycle.
Nov 06, 2017 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwasher fills up with water put wont go into wash cycle and wont drain
your drain hose is probably plugged to the drain especially if it goes through the garbage disposal first,remove drain hose from dishwasher at the disposer and see if its plugged,if so unplug obstruction,then start it and put hose in sink and press drain/cancel and see if it drains now
May 12, 2012 | Hotpoint Dishwashers
Wont do drain cycle,goes back to wash cycle
check the drain hose and the kitchen sink drain outlet are clear.
It is possible the soil sensor is faulty and is drawing more water thinking the dishes are still dirty. Check if you hear the drain pump operate briefly during wash cycle.
Jul 30, 2011 | KitchenAid 24 in. KUDP02CRBS Stainless...
Water will not drain .cycle stops , will not start even on new cycle
The water will have to be evacuated first. there may be a blockage either in the outlet of the dishwasher or the drain connection under the sink. The dishwasher tries to drain at the very start of the cycle. If this doesnt happen then a new cycle wont start.
Jul 31, 2010 | Dishwashers
Wont drain
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
Jun 06, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
Kitchenaid dishwasher won't drain someone opened door during cycle will this cause a problem
Opening the door wont matter. If you stop the cycle during a run it will always go into a drain. You might have a plugged drain line or burnt drain pump..
Apr 04, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Wont drain, no pump
Hi it sounds like a blocked pump needs cleaning out
Feb 17, 2010 | Dishwashers
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
GE Nautilus 24" Built-in Dishwasher Logo
197 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
