Question about Husqvarna 23 Hp 48" Deck Yard Tractor
When puting snown blower belts are too loose and will felt off
I have tried to change from grass cutter to snow blower, but when I make changed, belts on tractor are tooo loose. Jon deere tractor, 48'.
Any idea how to put the belts the right way?
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
  • 246 Answers
SOURCE: motor problem
Hello bartekzag:
From your Description it Sounds like Water in the Gas, Valve Clearances Require Setting or the carburetor Solenoid Requires Replacing.
>>If this is a New Mower and Under Warranty, then Return the Unit to the Dealer.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
Posted on May 14, 2009
  • 437 Answers
SOURCE: I have a yardman 46 in cut riding mower, it is
Well one of the spindle assemblies, could be running a little slower on one side then the other. But I would take a guess that you are trying to cut grass, way too fast for the mower. Try running a ground speed a liitle slower and see what happens.
Good Day.
Posted on Oct 07, 2009
  • 1584 Answers
SOURCE: Hi, I've misplaced my user manual for a Husky
Without even seeing the mower they are usually removed by loosening the bolts / nuts that secure the main cutter shaft, Look for slotted holes with bolts in is a giveaway.
Posted on Jan 20, 2010
SOURCE: I put mulching blades on my Husqvarna riding mower
thers usually a plug that goes into the discharge check your owners manuel for the correct part #
Posted on Aug 23, 2010
Snow blower works great but belt keeps burning and getting loose.
Hi Alan:
A burning belt is usually an indication that the belt is slipping.
Slipping can occur as a result of it not being tight enough, or because it is experiencing load that exceeds the friction that exists between the belt and the drive pulley.
I would check the belt tensioner (spring) to make sure it is adjusted TIGHT, and try to avoid really loading up the auger/fan assembly.
Hope this helps.
Jan 26, 2016 | Garden
Change auger belt on noma snow blower
Feb 22, 2015 | Garden
24 in aries snow blower throws snow for maybe 2 ft any ideas
Since your snowblower is a two stage all metal unit the only thing keeping the snow from shooting out is either a worn out drive belt or a weak engine. The belt is the easy thing to change. Buy a new drive belt too since it is a good time to change both at the same time. The unit actually breaks into two parts at the back of the auger housing to expose the belts for changing. A local shop can do this service for 100-$200 bucks along with an oil change and chassis lube. Not too bad since this will keep your unit running reliably for years to come.
Feb 14, 2015 | Garden
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I have a yard machine 5hp 22" snow blower. The
Sep 25, 2017 | Yard Machines Garden
Changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Your Craftsman manual will show you step by step how to change th belt.
You can get parts for you Craftsman and most MTD made models through With other makes you can get parts through
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman 16" High Garden Tractor Snow and...
Engine stalls when on cutter mode
some mowers have a reverse cut off switch when the deck is down this may be you problem(please rate this) hope this helps.
May 20, 2009 | Garden
Snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Dec 13, 2008 | Toro Blowers Rake and Vac - Electric...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
