Question about Maytag PAV2300 Top Load Washer
WASHER DO NOT SPINNED THE WATER OUT
MY WASHER WILL FULL UP WITH WATER BUT IT WONT SPINNED THE WATER OUT. WHAT COULD MAKE THAT NOT WORK.
  • mikemurdock Jan 09, 2009
    water wont stop filling but draining at the same time cause the machine doesent fill up with water please somone help me
  • 640 Answers
Im asuming it will wash...check your lid switch...
Posted on Jan 18, 2009
My washer wont spin,
If you had to empty the water manually, i.e the outlet pump did not drain the water out then I would suggest the pump is either blocked or has failed. This will normally prevent the spin cycle from occurring. Try checking and cleaning the pump filter out.
Dec 31, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer wont work
This sounds like the lid switch went bad. If you put it back on the wash cycle and it agitates, but will not pump out and spin, more than likely it needs a new lid switch. If this helps, please rate my answer. Thank you. If it doesn't help, we will take it further and try and get you fixed up.
Jan 06, 2010 | Roper RAS8445KQ Top Load Washer
Washer stopped while it was full of clothes and wont drain/spin
this is the problem with my machine what do you think i should do?
Nov 25, 2009 | Whirlpool LSR7333 Top Load Washer
My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
Sep 16, 2009 | Washing Machines
ALL FUNCTIONS OF WASH CYCLE WORK EXCEPT WATER WONT DRAIN AND SPIN CYCLE WONT WORK,
Pump is blocked or shot
Pressure switch made telling the machine it is full of water hence no spin.
Drop hose into bucket to drain the water off and the machine should spin, you may be better dragging the washer to an outside door and let all of the water run away at once .
Make sure that the drain hose is unclipped from the back of the machine so that the bottom of the hose is as low as you can get it
Jun 25, 2009 | Roper RAS8445KQ Top Load Washer
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Full of water wont drain
had trouble with some washers not dumping water found penny screws and other small material in the pump removed and worked o k .this might help.hum might be from restriction in pump.
May 21, 2009 | Kenmore Washing Machines
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
Maytag PAV2300 Top Load Washer Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
