Question about Panasonic DVD-RV31 DVD Player
Who can i send my dvd player too to get repaired the dvd player won't open I think a gear is stripped out or something.
    Genius:
  • 1,199 Answers
Http://www.pstc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 will tell you the best location in your area to have it sent for repair!
Please rate my response and help keep this site FREE!
Posted on Jan 06, 2009
Samsung blu ray player, dvd drawer will not open
Either the loading belt or loading gear wheels have the trouble. Sometimes the disc loading mechanism might need replacement. It won't cost mor for the mechanism. But will feel some difficulty in getting it from open electronic spare part market. it will be best to contact the authorised service center for Samsung to get it repaired.
May 12, 2012 | Samsung BDD5500 Bluray 3D Player
I have a samsung blu ray player and the tray won't
The timing gear is out of sync, to reset the gears requires training and skill that cannot be explained on this site, you need someone that knows what they are doing, or the gears will end up getting stripped making matters worse.
Apr 21, 2012 | Samsung Televison & Video
Door won't open to insert dvd
The gears are jammed, the timing gear is out of sync, or a broken loading belt, or cogwheel.
Apr 19, 2012 | RCA DRC233N DVD Player
Door wont open
You may have a timing gear issue, broken loading belt, or stripped gears.
Mar 14, 2012 | Toshiba DR410 DVD Recorder
The tray on player won't stay closed therefore I can't play a dvd.HELP
It sounds like there is something inside the dvd player, that isn't supposed to be there, that is keeping the tray from retracting fully. Try unplugging the unit and gently turning it upside down and giving it a little shake. Not too hard. This might jar the item loose, you will hear it knocking around. If you do knock something loose turn the unit so the front is pointing up and let the foreign object fall to the back of the unit where it hopefully won't interfere with the operation of the mechanisms inside. If you don't hear something come loose, remove the screws on the bottom, sides and back of the unit to remove the top cover. Make sure you have unplugged the power before you do this. take a look and see if you can find something jammed in the track or the gears for the tray. If you do gently remove the item with your fingers or a pair of needle nose pliers. Once removed replace the cover and away you go. If there is nothing blocking the tray and the mechanism, you probably have a gear system to close the tray. At some point someone must have pulled fairly hard on the tray causing the gear teeth to jump, check and make sure they aren't damaged or stripped. You are going to have to them either remove one of the gears (or pull it up so it can turn without turning any other gears) push the tray back into the fully closed position and replace the gear. Once you have done this you will want to test to make sure the tray will function properly. Place the top cover back on, but don't secure it with the holding screws in case you need to open it back up again, plug the unit in and test the tray. If it works unplug it and secure all the screws for the cover and away you go. Otherwise you are going to have to play with the gears till it is back in the proper starting position. If your hearing some strange noises and its not working, then the gears are probably badly stripped. You can contact the manufacturer and see if they can sell you some spare parts or direct you to someone who can replace it. Though at this point simply replacing the unit may be less expensive.
Jul 26, 2011 | Zenith XBV243 DVD Player/VCR
I have a soniq b100 disc player, which only responds intermittently after only 6 months since purchase. The player won't turn on, the buttons on the main unit have stopped responding and the remote...
Sorry, no there isn't much you can do at a consumer level with this player, except, if you still have a manufacturer's warranty, taking advantage of it and sending the unit back for warranty repair/replacement (whichever they suggest to you). It is clearly malfunctioning, beyond user control - send it back as a warranty claim (if you still have one on this model). It won't cost you in repairs that way.
Don't put up with a defective product, send it back - get it fixed under warranty free of charge (if applicable), or the unit replaced (again, if under warranty, free).
It won't cost hundreds of dollars and shouldn't take forever to resolve this simple case. Good luck. This is something the manufacturer should worry about; not you.
May 06, 2011 | Televison & Video
My 19 in magnavox tv dvd combo makes a rattling noise after i put a dvd in and try to play it
Sounds like you have something in it or the gear drive is bad. Open the door and look inside with a light. If you do not see any loose objects then I think you have a bad drive gear which would not be feasible to repair given the price of a new 19 in tv and dvd player...
May 05, 2011 | Televison & Video
Cant open dvd door: dvd is stuck inside player and will not eject...door cannot be opened.
You can force a dvd player to open. If you noticed there's a small hole in your dvd player as big as a paper clip. All you need to do is to find a paper clip and use it as a key to open ur dvd player.
Mar 19, 2011 | Toshiba Televison & Video
GPX DVD player w/surround sound
Have you opened it first and looked for a blown fuse. I suggest you unplug the unit and first look for a blown fuse. If this does not help, go to the retailer or the store where you purchaced the unit and see who they send them to for repair. Good Luck
Mar 19, 2007 | GPX DV-1010 DVD Player
Problem with Sony DAV C770 DVD player
theres a mechanical system inside this unit that most of it is made out of nylon or plastic gears and levers so im thinking that somehow the unit broke one of the gears or cams and cant complete its cycle or somethings inside the unit like a paper cd label or something liker that But my moneys on a broken loading mechaism and the onlty way to fix that is to get a complete mechanical service manual and start from sratch with the alighnments and then you will see when one isent in the right spot. This is not an easy repair unless you do these makes and models all the time as there are so many alighnments and gears that it seems how did this ever work>?? good luck PS send this unit to someone who knows!!
Apr 21, 2006 | Sony DAV-C770 System
Panasonic DVD-RV31 DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
