Question about Dell 5650 Computer Speakers
Speakers fade in and out when listening to music
I have just recently moved my computer to a new residence, and now my speakers are not working properly. When I listen to music it fades in and out. It will go from the volume that I have it set at, to a lower volume, then back up. This is not something that happens right away, it takes a few minutes of listening. I would appreciate some feedback as to how I can fix this problem.
  • 7 more comments
  • Michael Tuccelli May 25, 2007
    Thank you very much for your help. Your solution worked great.
  • Michael Tuccelli Jun 05, 2007
    Computer speakers started fading in and out again. The speakers will jump up to a higher volume randomly and then shoot back down to what it was set at. I have tried to fix this by unplugging the speakers from my surge and directly plugging it into the wall, also I have disconnected the whole system and then connected it. I tried the last solution and it seemed to help for alittle while but then, it came back. Could it still be dust or maybe my sound card ot r are the speakers just crap?
  • Anonymous Apr 11, 2008
    speakers was fade in and fade out the light also the same
  • Anonymous Apr 27, 2008
    My speakers do this, as well. They were working great until recently, when I noticed that they were fading in and out, with the volume changing and the speakers sometimes just cutting out. It even happens when I plug the jack into my iPod, so it's definitely the speakers.
  • Anonymous May 03, 2008
    My volume gets louder and returns to normal setting randomly. I re-inserted all connectors & cleaned the volume pot with alcohol but it still has the problem. Do you have any information what may be the cause? Email me at johnb12@optonline.net
  • Anonymous May 04, 2008
    Everything here is exactly the same with my Dell 5650. They worked good for about a year and a half. The volume fluctuates with a CD player also. Definitely in the speaker itself (not the sound card).
  • deadfred Jul 28, 2008
    Yep, I have the same problem with my Dell MMS 5650 system...
    The symptoms: volume randomly varying, sometimes much lower and then much louder.
    I have been testing with headphones on the output of my Creative X-Fi card and the volume is consistent. The problem is within the subwoofer/amplification circuit. I have ordered a replacement system and will open the old unit and fault find once it arrives.
    I'll post a solution once I fix it if possible but it looks like there is a inherent problem with the unit as all outputs FL/FR/C/RL/RR are affected. Could be a faulty FET as posted here:
    http://www.fixya.com/support/t597101-fin...
  • Anonymous Nov 07, 2008
    I am having the same problem can someone help me with this volume promblem
  • Anonymous Nov 30, 2008
    I've had this problem for quite some time on my computer.  It has also happened on a system my dad has set up in his garage which is an iPod directly attached to computer speakers (but with no computer).  Maybe it's a power issue?
  • 883 Answers
Ensure all connectors are properly inserted, then if you have a speaker mounted volume control, then run it back and forth rapidly about 100 times with power off. this will allow the tiny copper "wipers" contacts to brush off any accumulated dust.
Posted on May 25, 2007
The replacement system came in as faulty too!!!!
This is 2 units in a row. There must be some problem with them. I have given up and bought a Logitech G51 instead. Sounds better too...
Posted on Aug 24, 2008
I listen to my iphone on my Logitech speakers on my desk. When the volume is low, the speakers work great. However, when I turn up the volume, the green light fades, and the speakers are scratchy. Is...
Hi Roxanne
Sounds as though the power-supply might be faulty. As you turn up the volume more power is required from the supply and it's not delivering - hence the light fading.
Jun 16, 2011 | Logitech LS11 2 Speakers
No sound coming out of speakers but lights moving on board
The Efx 12 has two outputs monitor out as well as mix out ( XLR sockets ). If the level bars are moving its an indication that the mixer is working. Have you tried headphones out as well as monitor out.
What is your amplifier and speaker setup- you have not mentioned it at all.
Even if any PFL switch is on you won't get sound out of the speakers.
PFL stands for Post Fade Listen and when any of the 12 channel PFL switch is on only the headphone out put will work.
May 18, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
Radio Interferance on my logitech computer speakers
You may be now living too close to a radio station. Sometimes when this is the situation, anything electronic gear plugged into a wall socket can act like an antenna, thus receiving signals from local radio stations.
Mar 10, 2010 | Logitech X-530 Computer Speakers
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
As i listen to music or videos the sound slowely fades and dies
If you are using media player, go into view and enhancements and scroll across and disable crossfading.
Hope this helps.
Apr 02, 2009 | Dell Computers & Internet
I have logitech x-120 speakers and cant get any sound out fo them
I have logitech 530 speakers, can only get 2 speakers and sub to work. Just installed new sound card. When I run a test on all speakers they work, till i try to listen to music, then only 3 work
Mar 09, 2009 | Logitech X-530 Computer Speakers
Alvan and The Chipmunks reside in my Gmax 2100 speakers!
If you have a sound card added on your motherboard, i suggest you uninstall the drivers, take off the sound card, attach it again and install the drivers.
If you connect your speakers through the motherboard itself, uninstall drivers and install them by searching C:\WINDOWS\system32\drivers
Hope it helps!!!
Mar 30, 2008 | Gateway GMAX 2100 Computer Speakers
My computers sound not working.
try new sound drivers for your model pc ok
Feb 07, 2008 | Dell A215 Computer Speakers
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Dell 5650 Computer Speakers Logo
4,744 people viewed this question
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
