Question about ASUS VW193T Monitor
I recently purchased an ASUS VW193T and the picture is streched out. I tried to use the menu to change the aspect ratio, but it is dimmed. First I connected using the DVI port, and then tried the VGA connection with no luck. Please help as this is the first time I've had this problem with a monitor. I'm using Windows XP. Thanks
  • 2 more comments
  • Anonymous Mar 11, 2009
    i have the same problem and i dont know how to fix it!!
  • Anonymous Mar 13, 2009
    I have the same problem! Help!
  • tjiewei Mar 28, 2009
    At the link above, no driver can be found.
    Only product spec and manual can be downloaded.
  • Anonymous Mar 30, 2009
    i have the same problem...damn asus dun have driver for the model...and they dont respond to my complain either....
  • 2,692 Answers
The picture on my tv screen is streched too large. How do i fix this?
get the on screen menu up
find the aspect ratio and adjust it to the correct ratio for the screen --ok-- then exit
if it is a digital tv it may be the pixel setting for the screen
Nov 23, 2015 | LG LM6700 47 in. Cinema 3D Smart TV
Tv screen streched top and bottom side
Go to the menu and select different aspect ratio or format.
Nov 15, 2011 | Televison & Video
I have recently purchased a LG LCD TV Model 32LK330. Everything seems to work fine except all of the people look as if they had gained an additional 100 pounds. Is this distortion natural.
It is aboslutely normal. The aspect ratios on LCDs are different from the good ol' CRTs and CRT based projection tvs. As a matter of fact when I got my first LCD tv, it took me a few months to get used to it. You can try other aspect ratios though by going to Menu-> Picture->aspect ratio and try the different settings available to see if any of them works for you.
Jul 14, 2011 | LG Televison & Video
Returning to "streched" picture as top of heads
Remote control is needed to change aspect ratio. The button on the remote is labeled format. Standard definition sources have six picture sizes and HD has two.
Bill W
Mar 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
Picture size doesn't fit the screen I tried to adjust the aspect ratio but the option is locked on the menu. What to do? (Olevia TV model lt42hvi
You cannot change aspect ratio when recieving HD signal. Try changing the cable box or satellite box format or aspect ratio.
Dec 30, 2009 | Televison & Video
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Normal and letterbox
"Normal" looks "streched" because the origin of the video is normal, so it gets streched. If you play a "letterboxed" material (may be a DVD) it comes compressed, (vertically streched) so when you play it in letterbox it streches up to the rigth aspect ratio. Take a look at it in wikipedia.
Jul 14, 2009 | LG 37LH40 37 in. LCD HDTV
Aspect ratio
increase the resolution to the maximum then check
Apr 17, 2008 | ASUS LCD Monitor
Picture too streched out
What is the make and model of your TV. Different brands label the aspect in other ways.
Nov 29, 2007 | Televison & Video
ASUS VW193T Monitor Logo
605 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
