Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
95 s-10 runs perfect but has no power at all
The service eng light stays on scaned the truck and it gave two 2-digit codes the first one 42 and also 44 code 42 = bypass or electronic spark timing (est) circuit 44= oxygen sensor or circuit lean exhaust detected so my question is does any one know how you would go about trying to pin point the problem or is there something that would be likeley to trigger codes 42 & 44 thanks for your time
    Problem Solver:
  • 10 Answers
The second code is generated by the first... since you have spark issues it causes the truck to run lean which in turn causes the lean exhaust code to show up... check your ignition coil, plugs and plug wires... your problem is more than likely in one of if not all of those areas...
Posted on Jan 06, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I had problems starting the van I change the ignition coil packs the thermastat it starts but always sound like has no coolant radiator is full service eng.light stays on had it scaned and get a code that...
Could be another sensor. These vans have like 2 or 3 sensors for most thing.
Or could be you need to reset the brain/mother board.
Hope this helps, good luck.
Feb 09, 2011 | 2000 Oldsmobile Silhouette
My service eng soon light stays on
Could be something a little as a gas cap, take it to Autozone they can do a free code reading, this way you'll know if it's something small or major, but if it's some thing other then a gas cap, have it check at a repair shop before buying any kind of sensor's.
Feb 12, 2010 | 2002 Ford F150 Regular Cab
Yellow enging light can on while friving to work.
yes, you will need to have the computer scaned to pull code,unless you have a scan tool i would take it to the dealer.who knows it may be under warranty.
Jan 06, 2010 | 2009 Jaguar XF
What the service engine light mean and how much horse power a chevy suburban have
Well, the first question is easy. It is the onboarddiagnostic computer telling you that there is something that is failing or bad in your vehicle....go to Schucks/O'Rielly's/Checker/Parts Plus/NAPA....they will read or help you read the codes that are causing your light.
Horsepower...what size of motor do you have?
Jul 12, 2009 | 1991 Chevrolet K1500
VSA CHECK ENG LIGHT COMES ON
Take your vehicle to a parts store and have them run a diagnostic on it. It will tell you what code came up and that will give you a good start.
Mar 22, 2009 | 2003 Acura 3.2TL
Starts then dies
check your fuel pump relay
Mar 06, 2009 | 1998 Buick Century
Reduced Enging Power
you are just going to have to change the pcm see if you can find one to just swap them out to verify the problem
Oct 31, 2008 | 2003 Chevrolet TrailBlazer
97' BMW Z3 chk eng light code 1423
code P1423 for a BMW is secondary airflow sytem bank 1, consult your repair manual and you can go from there. I am not up on imports to be honest but I was able to find out what the code means for you. hope it helps.
Oct 07, 2008 | 1997 BMW Z3 Roadster
Egr valve were is it located on the motor car failed emission twice mechanic said change it be okay that oroxygen sensors
Hello do you have engine service light on and if so was it scaned with OBD 2 scaner to retreve this fault "EGR" service eng light would be on if EGR is at fault! did you change your oil before E test and what is your milage on this car and do you know if you engine is a long "BLOCK" or short Block"
Jun 23, 2008 | 1993 Dodge Intrepid
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
438 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
