Question about HP Pavilion DV9825NR Notebook
New hard drive
When i try to load windows xp on this,windows setup starts loading files then press enter when they stop loading,It says(,Setup cannot find any hard disk drives installed).
  • gg79 Jan 06, 2009
    where do i get them,and apply them?
  • HP Master
  • 4,806 Answers
Hi there
You need the SATA drivers for your machine to recognize the harddrive
Posted on Jan 06, 2009
  • Lee Hodgson
    Lee Hodgson Jan 06, 2009
    have a look here for them >>>
    http://www.tacktech.com/display.cfm?ttid...
    good luck
I got a Imation Apollo ii 320gb portable hard drive which is detected on my laptop and not on my desktop both run on windows xp.
Try to reload the operating system you are using i.e windows xp,one of the windows files may have been corrupted and how can you load it. if you have a important files on your desktop try to copy it into any storage device such as flash drive or memory card after you have transfer those files to the backup you use as your storage device unplug it from the system then format the system and load it with your windows xp any one that support service pack 2. how can you format and load your system. in the start up of the system press the key your system support to enter setup some system like compaq for you to enter their setup you have to press F10, some system support DEL to enter setup and some system support F1,while some support F2, any one your system support press it when you get to the setup area to advance setup or check those drop list one after the other until you see were you see booting or booting sequence or booting other then set your CD rom to the first boot follow the order the system give to you then save your setting by pressing F10 key or move your cursor to where you see save and exit and press the enter key for the system to restart then insert your operating system software i.e windows xp immediately the system restart and boot it will bring press any key to boot from cd rom then press enter key then follow the instrution.
Jun 08, 2010 | Imation Apollo (27119) 500 GB USB Hard...
Hi my everex computer is getting a screen saying windows could not start following file js missing or corrupt:..windiwssystem32configsystem............How do i repair without loosing my downloaded pictures...
Hi, Assuming the OS as XP. Plz follow the below steps.
Yes, you can repair your system,
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
May 23, 2010 | Everex StepNote NC1500 Notebook
Gateway MX6455 - AMD Turion 2.0Gb with 1Gb Ram Stops working and goes to black screen after POST. Will not boot into windows. The more I try re-booting, the faster it stops.
If you recently installed and any new program it could be a corrupt driver. Boot to safe mode by hitting F8 and delete it. If you didn't, you will have to remove drivers individually. Failing hardrive is another culprit.
Mar 04, 2010 | Computers & Internet
My PC need help
one chance is there for you. just do a repair which HDD drive is detecting win32 missing. just follow these steps.
Please read carefully and make sure you followed the warning links before initiating
the Repair Install. You can print a text version for reference. repair.txt
installations.
Warning
Apr 05, 2009 | Computers & Internet
Cant start computer
Try this:
boot order in the system BIOS. Check your system documentation
options below This portion of the Setup program prepares Microsoft Windows XP to run on your computer:
Recovery Console, press R", (you do not want to load Recovery
read the Warning listed later!!
When your system reboots, Do not press any key to boot from CD when the message appears.
Feb 12, 2009 | Lenovo 3000 J115 (7387-A11) Desktop...
Os keep restarting. on boothing the laptop, the windows starts and the user interface loads. when ask for username and password, on entering the username and password, the laptop restarts.
From my point of view I think the Operating system needs to be Repaired and below is a guide on how to repair
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
  3. Press ENTER to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R", (you DO NOT want to load Recovery Console). I repeat, DO NOT choose "To repair a Windows XP installation using the Recovery Console, press R".
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read WARNINNG #2
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact. After the installation is over the system will reboot.
Enjoy
If This Solution has Worked Please RATE ME!!!!!!!!!!!!!!!!!!!!
Oct 22, 2008 | HP Compaq Presario 2200 Notebook
My laptop is not switching on
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Oct 22, 2008 | Toshiba Computers & Internet
Assist with an Operating System start issue? PC is a Gateway GT5228
the following will re-install windows without destroying your stuff but you must follow it exactly !!!!!!!
  3. Press Enter to start the Windows Setup. To Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" height="21" alt="To setup Windows XP now and Repair Install , press ENTER." src="http://www.michaelstevenstech.com/note.gif" width="15" border="0" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  7. good luck beergut707
Oct 09, 2008 | Computers & Internet
I reformated my hard drive and I cant load windows
1.Make sure the hard drive is installed correct and the bios found it.
2.In bios you have to put the cd/dvd as first boot and the hdd at second.
3.Load the original windows xp disk and restart saving changes in bios.
4.When prompt to pres any key do so.
5.Continue setup as new install. (if a miss one excuse as im thinking the step)
a.Enter continue
b.F8 I agree
c.d delete
d.enter sure
e.L delete
f. C create partition
g.Enter create
h.Enter Install
I.NTFS Quick Enter
Lets windows format copy some file and make a restart.
Keep windows setup all the way.
Install drivers and that it.
Let us know thanks.....Hope this help....
Sep 11, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
Windows XP professional loop
Glad to hear you have your OS disc handy... let's try this:
Insert your XP CD and when it asks if you want to boot from the CD, press any key (ENTER) to do so. When asked, press ENTER ("To setup Windows XP now") and follow these steps...
To repair a Windows XP installation using Recovery Console, press "R"
To quit Setup without installing Windows XP, press "F3".
Press Enter to start the Windows Setup. DO NOT choose "To repair a Windows XP installation using the Recovery Console". You Do Not want to load the Recovery Console.
Select the XP installation you want to repair from the list and press "R" to start the repair.
((Note: If Repair is not one of the options, END setup. After the reboot read Warning#2! ))
Setup will copy the necessary files to the hard drive and at some point the system will reboot. When this happens, you want to now allow the system to boot from the hard disk but leave the CD in the drive. So do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Hope that helps.
Sep 09, 2008 | Microsoft Windows XP Professional
HP Pavilion DV9825NR Notebook Logo
69 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
