Washer not spinning
Is not spinning out the water. Any thoughts? I have all 4or5 lights on the right side flashing at once.
  • 15,935 Answers
The motor controller and ECU should be checked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Washer will not spin or ajatate. I need to remove the front panel to see what up?
Use downwards force to relieve tension on the spring clips holding that front panel on.themobilian_1904.jpg
Video how to:
Once yall have the front panel removed yall will notice the motor has a green blinking light on it.
The motor blinks on and off all the time It blinks faster when running. That is normalment mon ami.
If it ain't acting right it will display flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes little green men (bad motor)
6 flashes locked motor check for objects between tub
7 flashes bad lidswitch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_26.pngthemobilian_27.png
Service manual and more HERE
Mar 16, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Will not spin
I'd say you most likely need a new Out of Balance micro switch this is on the right hand side under the main computer (motor controller module) Which is in the top of the machine. Does the machine also stop and start while filling? If so this is a very cheap part so try this. Does the machine stop and beep at you, if you leave it going? if so which lights are flashing? cheers
May 04, 2009 | Fisher and Paykel GWL11 Top Load Washer
Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
Mar 14, 2009 | Amana Washing Machines
Whirpool LSQ9200LQ Top Load water leaking on start of pump out
Transmission may be bad. When machinbe goes into very start of spin it should drain the water first and then machine will actually spin; tub should not be spinning. If it is, water cyclones up sides and will come out at tub cover. Only fix is to repl trans or select lower water level if I am correct in the diagnosis.
Nov 30, 2008 | Whirlpool LSQ9600L Top Load Washer
Machine will not work and flashes 12 minutes
remove bottom cover look for tech sheet usually on right side of cabinet at bottom fh is usually a water fill issue drain may be siphoning water may be slow filling or bad flow meter flow meter may be harder to diagnois but try tapping lightly with screwdriver (it's the round object left side with 2 small hoses attached ) slim chance may be pressure switch left side rear corner
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Motor won't spin, with flashing "End" light and 3 beeps
this should be a blocked pump or waste pipe or pressure switch ( round grey disk with small pipe off the drum)
Aug 15, 2008 | Tricity Bendix AW1400W Front Load Washer
My AW1400W does not working
mine does this ..alot. its usually limescale buildup or other obstruction in the connector to the drainage pipe under the sink. One time it was limescale in the main filter down on the bottom righthand side. a real pig to get out and to clean!
Will not spin out
Is the machine draining the water out? The machine will not spin unless the water is pumped out.
Oct 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
