Question about Citizen Eco-Drive Aqualand BJ2000-09E Wrist Watch
New watch will not move from "NG" position
Watch has been out of box and exposed to light for 4 days. I have performed both of the reset option which got the second hand to work normally, was every 2 seconds, what else can I try?
  • 623 Answers
This watch is known to have a long "startup" time, i.e., it takes a while to get a full charge. I suggest that you expose the watch to sun light directly for at least a day if possible, or put it under strong fluorescent lights for 24 hours to see what happens. Hope this helps.
Posted on Feb 27, 2009
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
Dear Sirs! My new (1month) Longines automatic watch hastens each day (and night) four seconds.Model L4.721.2 Is it normal or I have to turn to the laboratoty to fix the problem?! Thanks a lot Iosif
An automatic watch that gains 4 seconds in a day is good.A new Rolex is rated at 5 seconds per day so 4 seconds is well within what you can expect for your watch.As a tip when the watch is off the wrist place on its side,gravity slows the operation of the watch just a fraction.This is called positional error and may help.
Aug 19, 2010 | Longines New La Grande Classique Presence...
Need manual for rolex daytona men's watch
These are the things you might need about the watch.
1. Turn the crown clockwise while it is in position 2 to manually wind the watch.It will stop if it has not been worn out or put in a watch winder for roughly two days.
2. Pull the crown out one notch to position 3 to change the time.Turn the crown clockwise to move the minute hand.
3. Push the crown back into the watch while turning it clockwise to return the crown to position 1.The crown should be tight to ensure the watch case is waterproof.
4. Operate the stopwatch and chronograph function by pressing the button located above the crown on the 3 o clock side of the watch.Stop the stopwatch by pressing the button again,Reset the stopwatch by pressing the button below the crown.
Jul 13, 2010 | Rolex SS/18kt Daytona
I own a Citizen Eco Drive Calibre 8700 Blue dial Romen letters. I have not used it for very long time (6 months). Now when exposed to light only the second hand works but the minute hand and hour hand do...
If your watch was not stored where it could have light shining on it the LI battery would drain completely. There is a possible solution although it does not work all the time. It depends on how badly the battery has been allowed to drain.
Setup a lamp that will shine on a counter 24 hours a day and set your watch there. It helps if the lamp is about 1.5 - 2 feet above the watch. A 60 watt incand. lamp will work fine.
Leave your watch under this lamp for 3 - 4 days 24 hours a day. This will supply the solar cells with enough energy to recharge the battery and get it working again. If after this time it is still not working then the battery is just not going to accept a charge again or there is something else wrong that a watchmaker is going to have to fix for you.
Hope this helps.
Yellowstone Watch Inc.
Nov 02, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
My watch has frozen at a particular time everything still functions it switches between time zones and alarm and all the hands move around but when set it just sits at the same time all day any help?
go to the citizen watch website and look for the e870 instruction manual. Look for the "all reset" function and perform.
The watch must be fully charged, and then perform instructions. It may have been jarred or emf may have hindered its process.
Try it and see if this corrects your problem.
Oct 08, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
New watch that wont charge
Usually this happens if the watch capacitor (same like battery with the only difference to store energy converted from light) is faulty and can't recharge itself to the needed voltage.
I would not recommend to try to do anything to the watch without aproppriate knowledge as Eco-Drive watches are quite complicated.
The best solution-- Find out your nearest watch repair shop and ask for a new capacitor replacement. Do not panic yet as this is no big deal and can be done quite quickly.
Of course, there can be something else wrong with the watch, but I hope this is capacitor as this usually is the most common with new Eco-Drives.
Do not forget to rate, please.
Jan 09, 2009 | Citizen Eco-Drive Aqualand BJ2060-58E...
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 | Watches
Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
Pulsar Mens Wrist Watch
I have a similar solar modle Ive had since 1995 , about 4 years ago it started loosing time and the second hand started double ticking. I sat it down out side on a cool summer day for the hole day in the bright sun and never have had a problem since. knock on wood! It was also runover by a car last year and still works good. I wont ever get ride of it. Hopefully this helps u guys out
Jan 30, 2007 | Pulsar PXF216 Wrist Watch
Citizen Eco-Drive Aqualand BJ2000-09E Wrist Watch Logo
107 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
