Question about Panasonic NN-T888S Convection/Microwave Oven
Panasonic Microwave Door Latch
One of the small door-hooks on our Panasonic NN-9850 / NN-9800
(750 Watts) broke and now the door won't open properly once it is closed. We need to stick in a ruler to lift the one remaining hook to open the door.
We can't find this part anywhere! It sure seems to be wasteful to throw out such an expensive convection microwave for the sake of a piece of plastic smaller than a fingernail! It otherwise works perfectly!
j.e.miller@shaw.ca
  • chrissy_stap Mar 07, 2009
    the door hooks have broken how do i get into the door?
  • William Miller
    William Miller May 11, 2010
    Did you find what the part number was for this part?
SOURCE: Panasonic NN 9850 wall micro/convection oven
PLEASE CHANGE MEMBRANE SWITCH
Posted on Oct 05, 2007
  • 2326 Answers
SOURCE: Panasonic NN-V671S 900 Watts Convection / Microwave Oven
User guide for your appliance.
Posted on Apr 24, 2008
  • 421 Answers
SOURCE: panasonic nnt774sf door will not remain closed.
You can purchase parts for Panasonic microwaves but home repair is not recommended due to them being lethal if you do something wrong. I would find a good local repair shop and they should be able to find the part and repair. It might not however be cost effective, depends on the part price.
Posted on Mar 11, 2010
  • 33 Answers
SOURCE: i need a manuel for
Here you will find the Quick setup guide and operating instructions: http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Countertop-Microwaves/model.NN-9804
Posted on Jun 09, 2011
  • 821 Answers
SOURCE: I have a Panasonic Model
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Posted on Aug 02, 2011
Panasonic NN-SN960S turntable turns on when door is open
This can be caused by a defective door latch or possibly a control board fault.
Aug 28, 2016 | Panasonic Microwave Ovens
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
Why does NN-SN651x Microwave sometimes starts, sometimes not ?
Adj door latch switch assembly. It is not aligned properly preventing the door hooks to engage.
Aug 31, 2014 | Panasonic Microwave Oven NN-SN651B
NN-T994SFR. Inclosed light stays on and the indicator states the door is open.
It is micro switch when you close the door, the door latch push in a button on the micro switch take lid off open and close the door and see if you can spot a button not popping out properly or the latch not in line with the switch
Oct 04, 2013 | Panasonic NN-T994SF Microwave Oven
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
The top door latch on panasonic microwave NN- T945SFX broke
it's a replaceable part. the upper and lower hooks are actually 1 part. door will need to be partially disassembled
Aug 03, 2011 | Panasonic Microwave Ovens
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Door Key Broke on Microwave Door
To replace the inner part of the latch is actually quite easy. Remove the glass tray from inside, then unplug the unit. Take to a flat surface and stand on edge so that the door will open flat. On the inside is a plastic trim that is just clipped on. Pop this off carefully and you will now see the assembly you need to replace. Note where the spring is anchored to the door before taking it apart. Put a small amount of lubricant on the guide pins of the new catch (petroleum jelly works great).
Dec 17, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-T888S Convection/Microwave Oven Logo
503 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
