Question about GE AGQ08AH Air Conditioner
How can I turn off the "beep" when settings are changed, either remotely or on the unit? The dog thinks it is an Invisible Fence warning.
  • Robert Frerichs May 28, 2007
    I was hoping there was a secret code like TiVo has for many extras. The "beeper" is on the circuit board and I was unable to cut wires to it, but the top was popped off and it went silent. Thanks!
  • 883 Answers
To reduce cost, many manufacturers have trimmed off many "extra" functions. i believe your unit had the feature to silence settings change removed to reduce cost. if you think you are up to it, do the following: open it, find the alarm beeper (may be on a circuit board) then cut one wire leading to it. if on circuit board then crush the beeper with vice grips if cannot de-solder it
Posted on May 25, 2007
GE APE07AHM1 Won't Run
This unit has a famous problem with the control panel. Try to use the remote to turn it on, instead of the panel. I had the same problem.
Jul 18, 2013 | GE APH10AA Air Conditioner
Hi. my room air conditioner model: hwr12xc8 timer is not working
Switch on a/c and then set timer. You will get beep sound. If no sound communication error between unit and remote.Replace remote.
Jan 04, 2011 | Haier HWR08XC7 Air Conditioner
Air conditioning unit is not responding to the remote
If you can't change the settings manually, then the control pad is bad. If you can and the remote won't change the temp or mode then the remote is bad and will need to be replaced.
Apr 10, 2009 | Heating & Cooling
Everything is fine but the the monitor blank
If your speaking of the topic GE air conditioner, then it sounds like the control panel has failed. There is not way to turn the display on or off.
Jan 28, 2009 | GE AGQ08AH Air Conditioner
LG Air Art remote
I don't think you can turn of the beep. Not without tearing it apart and removing the internal speaker, is it really that important? The temp sensor is in the unit.
Jan 06, 2009 | LG Electronic Window Air Conditioner
AS12S4GB AIR CONDITIONER 4 BEEPING
when you restart the unit monitor the outdoor unit and see if the compressor and outdoor fan starts up . before the beeps . you can try reseting everything by disconecting all power to outdoor unit .
hope this helps please leave fead back / keep me informed
Oct 20, 2008 | Samsung AS18A6RB Air Conditioner
Fedders Air conditioner
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
Jun 07, 2008 | Fedders A6P09S2A Air Conditioner
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
GE APH10AA - beeps once when plugged in but doesnt turn on
It could be just the start capacitor for the compressor that has gone out. Easy way of checking is to take a screwdriver and short across the leads after you have unhooked it from the wiring connectors (don't touch metal while doing this, it CAN shock you) and take an analog meter, put it on ohms for resistance, and touch it across the two connectors. The meter should jump, then switch leads and touch them again. It should jump consistently like this. If it's not that, then it's probably either faulty wiring, switch or if all else fails it could be the compressor went to ground. Take off the leads going to it, again set the meter to full resistance, and put one lead on copper tubing going into the compressor, and touch each pin of the connector on unit. If any of them read anything, then it is the compressor. Hope this helps.
Aug 05, 2007 | GE AGQ08AH Air Conditioner
Heating & Cooling Logo
136 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
