Question about Bose Companion 2 Computer Speakers
Bose COMPANION 2 Speaker case disassembly?
Companion2 series 2 computer speaker cases.. How do these darn things disassemble? I can see no external screws or pry points.
  • Anonymous Jan 19, 2009
    my speakers come in and out - sounds like a wire is shorting out.  I cannot figure out how to take the speaker apart to look at the wiring. There are now screws and I'm afraid to pop the front off with a screwdriver.
Yes..the only solution is to pop the front panel with screwdriver...to do this more efficiently (without breaking the front panel) ...first insert the thin screwdriver in the gap in front lanel on side wall...and rotate the screw driver 90 degree..this will pop that side....repeat it on other sides too...i did it last night only.....
my problem was that when i dropped the speaker....its magnet fell down...and its no longer working...i am trying to find another broken bose speaker to replace mine...from e bay,,but no luck till now :(
Posted on Jan 26, 2009
  • Wayne of Welling
    Wayne of Welling Nov 05, 2013
    As above with the grill (it's glued in has 3 toungs either side & 2 each top and bottom). The speaker has 4 screws which are easyaly removed.
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
Bose Companion 2 speakers and Windows 7
Scan your computer with RadarSync so that it will detect which driver updates are needed. It will grab the drivers and update them.
David
Jun 26, 2013 | Bose Companion 2 Series II Multimedia...
Problems with bose companion II 12 volt adapter
I found that the 12v power pack from an external hard drive works fine. I think you need the 5.5 x 2.5 mm plug.
Jun 12, 2012 | Bose Companion 2 Series II Multimedia...
Can you use your tv remote on the bose companion 3 series 2 multimedia
Unless it came with a remote, there is no way to hook these up to a remote.
May 03, 2011 | Bose Companion 2 Series II Multimedia...
Would like to know how to open speaker cabiant.Bose companion 2.
currently trouble shooting Bose Companion 2 computer speakers, no sound from speaker, would like to know how to open cabinet to see if wires are attached to speaker?
May 24, 2010 | Bose Companion 2 Computer Speakers
I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Dec 14, 2009 | Bose Companion 2 Computer Speakers
Bass rattling on Bose Companion 2
My Companion 2 speakers were having the same problem with the rattling on certain frequencies and I am happy to say that Steve Allison was correct in my case. The speakers don't handle surround settings very well so if you're running your speakers through a source that had that setting turned on the easiest way to stop the rattling is to just turn the surround setting off. The speakers weren't really made to handle that kind of a signal.
Jul 14, 2009 | Bose Companion 2 Series II Multimedia...
Not working on my hp
make sure there turned on or make sure it`s in the right AUX input
Apr 13, 2009 | Bose Companion 2 Series II Multimedia...
Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Feb 11, 2009 | Bose Companion 2 Computer Speakers
Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Mar 09, 2008 | Audio Players & Recorders
Bose Companion 2 Computer Speakers Logo
8,546 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
