Question about Jensen VM9410 Car DVD Player
Vm9410 missing amp remote wire on harness
It's the blue with white stripe. Where on the harness is it located?
    Problem Solver:
  • 7 Answers
If you cant find that blue with white strap wire, you can tap the wire coming from your acc to remotely trun on your amplifier. some players dont come with a remote wire for the amplifier and power antenna.ü
Posted on Jan 06, 2009
Have a kdc-138 radio which wire do i attach the remote wire to get power to my amp
hi robert, attach your remote wire from the amplifier to the blue/white striped wire of the harness of your kenwood unit. the wire should be labelled "p.cont". cheers!
May 22, 2012 | Kenwood KDC-138 FM / AM Receiver
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Alpine head unit CDE-9870 will not play sound through speakers of a 2003 pontiac vibe. what could be some issues to cause this?
This generation of Vibe may have the upgraded audio system installed from the factory. In order to get the audio from an aftermarket radio to play through the factory amp, the factory remote turn-on lead must be located. If you are using an adapter harness, it may have the wire installed, just attach the blue/white stripe wire from the Alpine to the blue or blue/white stripe wire on the aftermarket harness adapter.
Mar 01, 2011 | Alpine CDE9870 CD Player
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
(Gray Plug)
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
Red,yellow and blue with stripe hooks to what into harness
some decks have a solid blue for power antenna and blue with white stripe for amp turn on. if you have neither a power antenna or amplifier, i would not worry about connecting those two wires. do makes sure they are capped off and have no bare wires showing, as they are hot when the stereo is turned on.
May 05, 2010 | Pioneer DEH-P2900MP CD Receiver...
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Find remote wire connection for sony cdx ca400
Should be a blue wire with a white stripe in the plug that goes into your unit if its missing take the harness to bestbuy or an audio shop and they can prolly stick a wire in the empty spot. hope this helps you.
Sep 16, 2009 | Sony CDX-CA400 CD Player
Vm 9410
go to a audio local seller and ask them if they have one they should be able to get you one
Jul 10, 2008 | Jensen VM9410 Car DVD Player
Stereo wiring chart
If you go to anyplace that installs car stereos you can purchase an installation harness that will connect directly to your factory harness in your car. That way you would only need to wire your Kenwood harness to the instllation harness and that is just a matter of matching colors from the Kenwood harness to the installation harness. All you need to do after that is plug it in.
The wiring on the Kenwood harness is as follows:
yellow = constant 12 volts
red = ingnition (12 volts when key is turned on)
black = ground
white = front left speaker positive
white w/black stripe = front left speaker negative
grey = front right speaker positive
grey w/black stripe = front right speaker negative
green = rear left speaker positive
green w/black stripe = rear left speaker negative
purple = rear right speaker positive
purple w/blackk stripe = rear right speaker negative
blue = power antenna
blue w/white stripe = remote amp turn on
brown = phone
orange w/white stripe = illumination
Jun 18, 2008 | Car Audio & Video
Jensen VM9410 Car DVD Player Logo
225 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
