Question about Compaq Lexmark Color Jetprinter Z12 InkJet
Lexmark, paper jams and prints in same place, over+++
My paper jams up in one side of my printer, Lexmark Z12, and it just prints over and over in the same place, how can I fix this problem, or is it time to throw the printer out? Any help is appreciated, thanks.
Deb
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
LEXMARK z12 IS PRINTING SAME LINE TWICE LIKE
uninstall/reinstall the printer software and drivers
Sep 14, 2009 | Lexmark JetPrinter Z12 color InkJet
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
My printer sounds like it's printing, but the paper comes out bla
Most likely cause is the ink cartridge needs replacing / refilling. Did it stop printing part way through a page?
Aug 17, 2009 | Lexmark JetPrinter Z12 color InkJet
Blinking lights on Lexmark Z12 printer
Unfortunately, the Lexmark website is set up so I can't provide you with direct links to the workaround for these problems....
Go here: http://support.lexmark.com/perl/support/support.cgi
Do a search on "blinking flashing lights + Z12"
and try to follow the steps outlined in the troubleshooting guides that calls up.
This is the most likely candidate, but there are others that could cause this symptom:
Lights Flashing on the Printer ID: 241
Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed.
If the power light on the printer is blinking, you may have a carrier stall. To check this:
First unplug the printer.
Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
Once the cartridges have been moved across, you can clip them out.
Try to print without the cartridges in the carrier.
If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
I hope one of these options will provide you with the solution to your problem. If not, please write back with a report of what you tried and we will try to help you further.
If I have managed to answer your question or solve a problem, please take just a moment to rate this posting....thanks!
  • Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed.
  • If the power light on the printer is blinking, you may have a carrier stall. To check this:
    1. First unplug the printer.
    2. Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
    3. Once the cartridges have been moved across, you can clip them out.
    4. Try to print without the cartridges in the carrier.
    5. If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
Mar 28, 2009 | Lexmark JetPrinter Z12 color InkJet
Alignment error after replacing black ink. Lexmark X5495
I found a pencil inside my printer and took it out. It was not easy but now it does not jams the paper. Disconnect the power cord and softly shake the printer from side to side making sure you are holding on to the top scanner door so it won't flip open and listen for anything rolling or loose inside. It just might be your problem.
Dec 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark z12 printer
Most likely your printer's cartridge settings are incorrect. You possibly have a black and white cartridge in your printer but your computer settings are for a color cartridge. First verify what type of cartridge is in your computer. Then find the printer your are using installed on your computer. If you OS is Microsoft then double click on the Lexmark z12 and click on printer and then properties. Another window will pop up. Click on Cartridge Maintainence and then click on Verify/Change Cartridge. Hope this solves the problem. It worked for me.
Sep 30, 2008 | Lexmark JetPrinter Z12 color InkJet
How to install if disk for printer is good for windows 95-98 and have windows xp
hi,
unplug the printer and lift the cover and manually try to move the print nozzle assembly back and forth to see if it will move to both sides fully, use a flashlight to see if anything is caught in the belt or sides, the Z12 is an old printer model and the belt may be worn to the point that it wont stay in alignment and might have to get a new printer, fortunately dedicated printers arent that expensive and maybe you can get one at a thrift store real cheap.
Jul 23, 2008 | Lexmark JetPrinter Z12 color InkJet
Compaq Lexmark Color Jetprinter Z12 InkJet Logo
74 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
