Question about LG DRN-8080-B for Dell Inspiron Series DVD Drive
Playing DVDs on Laptop through the TV
I have bought a s-video cable to enable me to watch my laptop through the tv. For all other purposes it works, however, I cannot watch dvds played on my laptop through my tv as the discs are copy protected. Is there anyway to enable me to watch the dvds on my tv using my laptop?
The DVD software is CyberLink PowerDVD.
  • mtoots32 Feb 02, 2009
    I have the same problem. Playing dvds or movies off the hard drive you dont get the picture.
    President:
  • 2,049 Answers
Here's what's happening... software companies like CyberLink subscribe to the Macrovision requirements for playing DVDs and protecting copyrighted materials.
Macrovision has approved numerous video cards for what they call "TV Out" which allows the movie to be displayed on your TV.
Unfortunately, your Dell Inspiron does not have a Macrovision approved and supported video card in it, so it gives instructions to the computer to disable TV Out and not allow it to play anywhere besides the computer.
Posted on Nov 17, 2009
Fujitsu lifebook a1130 not detecting my TV
check under display settings you may have to enable or identify the monitor manually.
Jun 30, 2013 | Fujitsu LIFEBOOK A1130 LAPTOP Laptop...
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
How do i connect my laptop to television to watch television on my laptop and record tv programmes on laptop.
You can't with most TVs (you would need a video out option on the TV and a video in on the laptop). Instead get a TV tuner card (to fit the slot on your laptop), a USB TV tuner or a set-top box for the purpose. Either use the included software or a program of a similar type for recording. (Windows Media Center probably will work.)
I hope this helps.
Jul 05, 2010 | Computers & Internet
I bought a component cable so i could hook my laptop to my tv so i can watch movies from my laptop through my tv and i cant figure out how make it work
I'm assuming that your laptop doesn't have component-video outputs, and you bought some kind of adapter cable?
I think that you may just need to tell your laptop where to send the video signal. The default is obviously the built-in screen, but most laptops can also send the video signal to both it's own screen AND the external output; or to the external output only. You usually have to type a combination of keys on your keyboard to switch through the modes.
For example: on my laptop you hold down the FUNC key and then press the F10 key (which also has a screen symbol on it). Check your laptop manual for that.
Some TV's can only accept video output from a computer at a certain resolution (like 1024 x 768). Check your TV manual, but you may have to adjust your laptops resolution.
Finally, since the video signal is not coming from cable or DVD, you will probably have to switch the video input on your TV, so that it knows where to get it's video signal from. This is usually as easy as pressing an INPUT button on your TV remote until you hit the right input, but check your TV manual.
Mar 23, 2010 | Toshiba Satellite A305-S6863 Laptop
Do i need to set my lap top to be able to watch tv.if so what ?
you can watch tv tuner its USB device for laptop allow to watch or install softwarefor more information refer to http://laptoplogic.com/resources/detail.php?id=46 you can getinformation about tv tuners
Nov 18, 2009 | Compaq Presario CQ60-220US PC Laptop
Rca tru flat tv has a red picture
Is your video input (from cable or satellite or fiber optic, etc.) coming from a coaxial cable, a component cable (red, green, and blue connectors), or an RCA cable (yellow connector for video)?
If you can, try an alternate input method and see if that makes a difference. Does it happen when watching DVDs or tapes, or when playing video games, or just when watching television?
Mar 13, 2009 | RCA TruFlat 27F520T 27" TV
TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
Nov 20, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
LG DRN-8080-B for Dell Inspiron Series DVD Drive Logo
142 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
