Question about Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive
Thanks for the advice
Thank you so much for replying but I am afraid I still can not see the external harddrive :( I can see it in the device manager in the pc and it says that there are no problems with the device, but I can't see it in the desktop. The same with the MAC I can see it if I use the disk utility and when I tried to repair it it tells me that it can't repair it because of an error.
    Scholar:
  • 76 Answers
Can you access the device using Windows Explorer?
For the PC: (Start/ Programs/ Accessories/ Windows Explorer)
I always use the Windows Explorer to move files for back-up or other reasons to my XHD.
The nice thing about this particular device is you don't need additional software.
Let me know if this gets you any farther
Posted on Jan 06, 2009
Pc does not see harddrive when plugged into usb port, had problem with pc had to reformat hard drive with external harddrive unplugged, now try to plug in and pc will not see it. very big probem please...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver:
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 29, 2011 | LaCie (300703EK) 250 GB Hard Drive
Hi, Thank you for email . I have a small Philips 250gb external hard drive model No. sde3275xc/97. It came into contact with some water 2 days ago and since then my laptop does not recognise it. It is not...
It's possible that a harddrive coming into contact with water would no longer be usable. You can have a professional recover the data, if the data on the device is important. Please check the info below:
http://www.ontrackdatarecovery.com.au/top-four-data-loss-tips/
You can also try placing the harddrive in a bowl of uncooked rice overnight. The uncooked rice will absorb the moisture from the device. Although I cannot guarantee this fix as its possible that water may have damaged the harddrive.
May 22, 2011 | Philips Computers & Internet
Appears as working properly within the device manager. But it does not show up in "My Computer". I have updated the drivers but still nothing.no sign in disc mngmnt either Any advice? Thank you!!
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Mar 05, 2010 | Coolmax HD-211-U2 Silver Slim USB 2.0 2.5...
External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 24, 2009 | IBM TravelStar 48GH 48 GB Hard Drive
Simpletech 1tbb harddrive failure
I had the same concern, I try finding drivers with no sucess, change usb cables, and a number of other fixes found on the internet.
Finally what solved the problem was pressing and holding the "One Click Backup" button for 30 seconds.
Apr 27, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
External Harddrive Not Recognized In My Computer
just change the use difftent port of notbook and same problem change the cable of external harddrive and problem is still present check the other laptop with this hdd and .................after last solutation is format your ext hdd ............more help send me feedback
Apr 09, 2009 | Compaq Evo N610C Notebook
My portable harddrive fell from a low table
i am afraid that the drive has gone, but you could try to fix it using disk manager application.
Nov 17, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Seagate 250GB USB external harddrive was working now it is not. Cannot see it in Disk Management. In Device Manager, USB controllers the harddrive shows up as Unknown Device when I plug it in. In...
unplug seagae usb external h/d
Device manager>Under usb= ,uninstall the device.
run: RESTORE, choose the last check point, reboot,then plug in the h/d in your usb.
May 06, 2008 | Computers & Internet
Unrecognizable USB External Harddrive
dear jpaws check your computers device manager. ithink you need drivers please install a driver.
Feb 25, 2008 | Computers & Internet
Reconization of external harddrive on my computer
Have you removed it at anytime before, if so better putting back into same usb port, or firewire or try using another one. Assuming all drivers have been loaded for the HDD. See if the drive is recognised, go to My Computer, right click then manage, then look at disk management and see if it's there. If not there and you know your ports are ok, then there is a hardware fault.
Jan 16, 2007 | Apricorn (EZ-BUS-100) 100 GB Hard Drive
Toshiba 250GB TOSHIBA USB 2.0 PORTABLE EXTERNAL 25 250 GB Hard Drive Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
