Question about Vestax Pmc07pro DJ Mixer System
Vestax mixer gold covers
Hey The gold covers on line-outs are missing from my mixer and I believe are the problem for bad sound quality.  Can I replace these without taking the mixer in? Where can I buy them.
They are the gold covers on line outs on back. Thanks
Yes this is a big problem. You need the gold caps to complete the circuit for each rca plug. They don't seem to be soldered to the unit, so it is very easy for them to come of and get stuck inside the rca cables.
Posted on Mar 09, 2009
Humming with vestax
hummm , does it also hum with the other gear shift out, especially tl and ledlights, if so it't a ground loop, but often is just the earth of the turntable not well connected
Apr 14, 2014 | Vestax Handy Trax Turntable
Noise , sounds like ungrounded, all the cables are fine , the connection is grounded
so its a buzzing noise. are your turntables grounded? some dont have to be. the buzzing could be several things feedback from something around you or the mixer is buzzing cause of to much power. just mess around w stuff your not gonna break it. and what i mean about that is more wires check wires. dont preform open heart surgery on your equptment. sometimes the buzzing means the faders are going i own 3 vestax mixers and on my pmc 17a right before the faders went i had massive buzzing sound.
May 31, 2011 | Vestax Pmc 280 DJ Mixer
Hello, I need assistance with my vestax pcv002 mixer. i need to replace the power cord since it has gone missing. Can i get just any generic DC15-A power adaptor or not? the proper vestax ones are much...
Provided the store which sells the universal type guarantees the voltage and current factor as available on the original Vestax, you can proceed to buy the type.
Also the product must be a good one to work without heating or have reduced life due to poor quality.
Mar 18, 2011 | Vestax Dc15a Power Supply
Had the amp 4 months and getting no sound apart from loud clicking noises when the speakon leads to the speakers are plugged in,ive gone as far as knowing its amp and not speakers/leads etc.its not had...
If the click is a one shot deal when you connect the speakers, I'd suspect that there is DC current on the outputs. Check using a DC voltmeter. You should read less than 0.5VDC. If you read more, there is a problem with the output section. Since this unit is new, it should still be under warranty. DO NOT open it up. If you read DC, return the unit for warranty service.
Please keep us posted,
Dan
Oct 27, 2009 | Vestax VDA1000 2-Channel Amplifier
Older vestax mixer PMC-25 has power surge and cuts out. If you bang the mixer sound returns but same problem keeps happening?
If you bang anything electrical and it restores it then chances are you have a bad solder joint somewhere. Out with the soldering Iron and start looking for a bad connection!
Sep 19, 2009 | Electronics - Others
The headphone jacks on my mixer(Vestax PMC-06 Pro A)not working
did you try the headphone jack in the back? also is the cue fader crackling when you move it left and right? also check if the cue fader is plugged in. if none of the above, check with your warranty
Apr 14, 2009 | Vestax Pmc06proa Thin DJ Scratch Mixer...
My dj mixers crossfader is not sensitive in the right range. i am looking for a replacement which is either adjustable or sensitive throughout. vestax mixer mdm 410
Hi Ray
Sounds like the fader has reached the end of its life. It should fade smoothly from one side to the other with equal audio from both lines in the middle. . You can get adjustable rate faders, but not for this model. if you do a search for a replacement (click here) there are plenty of places around the world to source one from. They are easy enough to change, overpriced in my opinion, but they dont miss you when it comes to replacements. Changing the fader will fix your problem I am sure. Thanks for using fixya. Good luck
regards
robotek
Nov 09, 2008 | Audio Players & Recorders
Vestax pmc 06 mixer / Virtual DJ Mix station
you need a sound card with headphone out seperate from master out
Oct 19, 2008 | Vestax Pmc06proa Thin DJ Scratch Mixer...
Low volume on both sides
Make sure you connected the turntable to the PHONO INPUT of your Vestax Mixer. If so, then the problem might be with your mixer output, or your sound system. You will need to test each unit individually to determine what the issue might be.
- OPTiC
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
May 20, 2008 | Technics SL-1200M3D Turntable
Vestax Pmc07pro DJ Mixer System Logo
290 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
