Question about InFocus LP725 and LP735 Replacement Projector Lamp - SP-LAMP-LP7E Projector Lamp
Infocus LP725 projector
Hello The projector will not work. I tried to plug it in and turn it on and nothing happens. I took and unplugged all cables except the plug in and tried but no avail. Maybe a blown fuse???? the power light doesn't turn on also.. Any suggestions???
    Scholar:
  • 58 Answers
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Posted on Feb 02, 2008
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
Blank screen
First check if the cables are working properly. Check for loose connections and any kinks in the cables. If they are fine, try a hard reset - Unplug from power source, remove cables. Wait about 10 minutes. Now redo everything and plug in. If it still does not work, then you will have to get the device serviced..
Oct 04, 2008 | InFocus ScreenPlay 4805 Multimedia...
Infocus LP350 won't show signal, also panel buttons don't light up
Hi LuckyLindy
Next time this happens , just take out the main connection to the Mainboard and plug it back in.
Also remember to reset your lamp timer now that you have replaced the lamp !
Apr 24, 2008 | InFocus LP350 Multimedia Projector
InFocus LP725
Hi there
Resetting the unit will unfortunatelly not work , you are facing replacing or repairing the Projector's Mainboard.
Quite expensive to do
Mar 13, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
Power problem
we were unable to pull the projector menu & it also took about 2 hours for the bulb to turn on.......the fan works, have changed the bulb, closed the bulb door & tried to reset the projector.......help!
Feb 24, 2008 | InFocus X1A Multimedia Projector
InFocus LP530 projector not powering on
the power supply needs to be replaced. it goes after a while in this model.
Feb 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
InFocus LP725 light goes out after 10 minutes
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
IN76 Pojector Just Turned Off, Will Not Turn Back On
same thing on my in76. a color wheel had to be replaced. projector is less than a year old an all parts and labour was covered.
Dec 30, 2007 | InFocus Play Big IN76 Multimedia Projector
395 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
