Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Acer 5920-6474 does not power on
By brdprince on Jan 06, 2009
When I plug my adapter (wall to adapter plug) green light on adapter is ON. When i connect the adapter wire to the laptop...the adapter light is FLASHING.. and NO POWER sign in the laptop...
no power at all in the laptop. Called ACER Tech and he said my ac adapter is broken or not working.
If anyone has / had same problem let me know...changing adapter solved or not.
Comments:
Jan 08, 2009
- OK, i tried to power up with fully charged battery (charged battery on other acer laptop-as mine is dead) still NO power. I was running all time on AC adapter and NOT on battery so i guess the computer is set on the POWER MANAGEMENT SETTINGS of AC Adapter NOT battery so it wont start on battery (some one told me above-dont know if correct).
ACER Tech says mother board mostly is gone..needs replacement. or ac power jack connection with the mother board. He doesnt know why its not starting with the fully charged battery. Other acer tech send me new ac adapter -tried- same-NO POWER
Can anyone tell what might be the solution and approx cost..
thanks
Same Problem
May 25, 2009
-   Same problem,my lappy pooched today with the exact same symptom. -   Guest
May 06, 2009
-   I am facing the same problem with same laptop.
I would suggest if anyone can suggest the resolution on the same.-   Guest
Mar 31, 2009
-   i have acer 5920 same exact problem will not power on .green light flicker when plugged into back of laptopunplug it light glows steady Please help i dead in the water-   fidders
Best Solution
posted on Jul 28, 2009
Very Helpful)
westwoodtec
Rank: Apprentice
Rating: 96%, 4 votes
the problem lies with failed smd capacitors grounding out underneath the motherboard on the same side of the board as the cpu heatsink. if you look at the board with the heatsink/fan in the top right hand corner- the culprit caps are in the bottom right hand region under some see through plastic. they are labeled pc144 and pc145.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jan 06, 2009
Not Rated)
honest1abe
Rank: Guru  Computers & Networking  Expert
Rating: 86%, 47 votes
Does your laptop power up on battery power? Have you removed all external devices (external monitor, keyboard, mouse, any USB device or expansion card, etc.)? Can you remove the CD/DVD drive? Do you feel comfortable removing the hard drive?
First remove everything you possibly can and see if the power adapter works. If it does, try adding and testing the items one by one to see which is causing the problem.
If the laptop will power up with battery and not with A/C adapter, it is very likely the adapter is the source of the problem.
Honest1abe
Comments:
Jan 09, 2009
- From what you told me, Acer tech is most likely correct. Laptop motherboards are not cheap and replacing them is best done by a professional.
There are a couple of options you might find attractive. Look on E-bay or Craig's list for someone selling the same make and model with a display problem. In other words, they have a dead or damaged LCD but the rest of the computer works well when attached to an external monitor. If you are lucky enough to find one at a very reasonable cost, you might be able to attach your LCD screen to the other laptop for a working computer. You could even swap out the hard drive with yours and everything should work getting you back to full functionality.
Another option is to go online or shop locally for a laptop repair shop. Get the rates up front and look for places that offer free diagnostics. They may be able to solder the joint on the A/C connector or even have a used motherboard replacement at a decent price.
A third option would be to put your laptop on E-bay or Craig's list and sell it as is and use the money with some of your own to buy a new laptop.
Honest1abe
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
where can you find p4m80p audio driver for xp
Answer
When i boot AX4b 533 powered computer I receive the message "Chipset not supported".
Answer
al my usb un recognize in my new Amptron Motherboard
Answer
i want intel 945gccr bios file of bios IC
Describe your Motherboards problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in , OH
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
