Question about Lowrance LCX-27C GPS Receiver
Gps will not turn on lcx 27c
Gps will not turn on. simulator works fine. Is the T required in the hook up to the antenna?
I have lcx 27c gps will not work locked up module not responding but has power to it
Posted on May 24, 2009
  • llf5210 Jan 29, 2011
    No solution posted!
Does it have achart plotter
Out of the box, no. To get GPS/Mapping/chartplotting features, you have to hook up a separate LGC-12S 12-parallel channel GPS receiver/antenna device which is sold separately.
Mar 11, 2011 | Lowrance LCX-15MT GPS Receiver
Transducer loses bottom at any type of speed greater than trolling. Worked fine last year with all the same setttings. All I can think of is , maybe the battery is low. The boat just came out of storage...
Check the transducer for any damage on the front part. Also make sure there isn't any damage on the bottom of the boat that is causing air bubbles to cross the face of the transducer. If it works at slow speeds there is definitely something causing air bubbles.
May 08, 2010 | Lowrance Lcx 27c 7" Gps Fish Finder Combo...
Radar option
No it will NOT operate radar.
Feb 24, 2010 | Lowrance LCX-27C GPS Receiver
Cannot get Lowrance LCX-27C emulator to work....
You can find it here...just follow the link.
Feb 07, 2010 | Lowrance LCX-27C GPS Receiver
With alcx-27c with gps do i need a transducer with the speed on it? or will my gps give me the speed my boat is traveling
The unit will give you speed over ground directly form GPS. there is a difference between Speed Over Ground (SOG) and ocean speed. Ocean speed will only be available from a paddle wheel type transducer.
Aug 10, 2009 | Lowrance LCX-27C GPS Receiver
Lowrance LCX-27C has power but only opens to the splash screen then powers down
The LCX-27C will draw up to 1.5 amps when powering up, if that amount of current is now available, it will power down. Double check your power connections. The +12vdc supply must be able to also supply enough current. Once you get it to stay on you can temporarily shut off the transducer by going into full mapping mode, or switch it to sonar simulation and the current draw will drop considerably. When you are ready for the permanent installation run solid connections directly to the battery and be sure to use the inline fuse for protection.
Jul 27, 2009 | Lowrance LCX-27C GPS Receiver
I have a lcx 28c hd fish finding sonar and mapping gps
I've had several similar units, and used them with Navionics HotMaps Premium series chips. You must select Menu. The "Browse files" to access the MMC card option. Once the selection screen opens, choose which card or file you want.
FYI...All of Lowrances HD models come preloaded with pretty much every major lake and river in the US.
Lemme know if this helps...
Mar 23, 2009 | Lowrance LCX-27C GPS Receiver
Im trying to change my lowrance lcx depth from feet to meters
Press MENU MENU. Scroll down to SYSTEM SETUP. Press the rigth arrow. Scroll to UNITS OF MEASURE. Navigate to depth and select METERS.
Feb 23, 2009 | Lowrance LCX-27C GPS Receiver
Turning on my Lowrance LCX 111HD fish locator creates static with my ICOM M502 VHF Marine radio.
Hello LJones0455. From your detailed attempts there are few options. Position the transducers one foward one aft. Connect the negitives of the battiers to the boat still route both positive & negitive wiring to all devices. Check the continunity of your transducers include flexing while ohming. Let me know of the results.
Oct 07, 2008 | Boating
Lowrance LcX 27C
You need to get a MMC card for it to show Canada.
Jul 02, 2008 | Lowrance LCX-27C GPS Receiver
Lowrance LCX-27C GPS Receiver Logo
439 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
