Question about D-Link AirPlus DI-524 Wireless Router
Cant connect ps3 wireless to dlink router
I have a hard wired pc and wireless laptop that work fine but i cant seen to connect my ps3. when i scan for network it finds the router but when i test the connection it fails when it looks for an ip adress. can any one help please
  • june873 Jan 06, 2009
    i tried both ways it acceses the access piont but fails when obtaining ip address
    alright when i hard wire it it comes right up
  • 43 Answers
The router should assign an IP address to your PS3 if it isn't manually configured. If you are connecting wirelessly make sure your security setting on your PS3 match your router. If the problem persists disable wireless security on your router and then try to connect with the PS3 with security disabled as well. Sometimes consoles have trouble connecting with WEP or WPA security encryption.
Posted on Jan 06, 2009
  • Johnathon Haywood
    Johnathon Haywood Jan 06, 2009
    Can you try plugging your PS3 directly into your router to see if it can get an address that way? This will help us narrow it down.
  • Johnathon Haywood
    Ok, disconnect the power from the router and leave it off for at least two minutes to reset in case the wireless has locked up. Keep the xbox near it for maximum signal. Disable the wireless security on the router and the xbox adapter. Fireup the xbox and see if it will connect in these prime conditions :)
My DIR-615 Dlink router always has the Orange globe. How am i supposed to fix this, the modem works perfectly fine as i tersted it without the router and internet works. But my wife needs the laptop and...
In the web interface of dir-615 switch it to router mode, adjust wan connection (username, password... depend on your Internet provider, in fact, it is easier to ask their tech support to provide all necessary information) then configure wireless network.
May 19, 2011 | D-Link DIR-615 Wireless Router
I have this router set up with a wired connection to a windows pc with windows 7 and using the wireless to connect a laptop and a ps3. when the wired pc is off the ps3 connects just fine, but when it is...
It sounds like you may have manually assigned the same static(constant) IP address to both the wired PC and the PS3. Check both the settings in the router, the PS3 and the wired PC to make sure that an IP address is assigned to both.
Feb 03, 2011 | D-Link DIR-615 Wireless Router
Cant connect to wireless network on my ps3
First off you have a wireless router hooked up to your ISP correct.
anually set a static IP for your wireless connection (When going through the network setup in Network Settings --> Internet Connection Settings (wireless), choose Custom instead of Easy when the page asking for either appears).
Set the IP address to something outside your DHCP range. e.g. 192.168.0.5 (for dlink router) or 192.168.1.5 (Linksys router)Default gateway should be the IP of your router. For dlink, this should be 192.168.0.1 and Linksys should be 192.168.1.1DNS Server can be the same as your default gateway, mentioned above.
Subnet Mask should be 255.255.255.0.If you're using some sort of encryption (WEP, WAP, etc), set it in there as well when it asks to do so.
And that should get you going. I actually haven't done this on the ps3, but its my info from experience with regular pc to pc networking.
Also If you haven't tried this already, change the wireless channel from 6, to 1 or 11 in your router and wireless consoles.
If all else fails, try this http://www.clanbluntforce.com/forum/index.php?topic=864.0
Nov 21, 2009 | Video Game Consoles & Games
I bought recently a lenovo laptop (G450) loaded with windows 7. I have wireless internet in my home that I use with my other windows xp laptop and it works fine. I never ever been able to connect to the...
have the same problem.  even after assigning a valid address statically to the network card and connecting with a wired connection, i cant even ping the router
Nov 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My ps3 cant find my wireless network anymore
get your router name and go through manual setup, your brother may have accedentally made your wireless network hidden, to change that go to http://192.168.1.1 or .0.1 and log in and chang the settings to default
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Can ping but cant connect to the internet
you may have to go to your routers ip address and see if you cant configure it to work or maybe your router can only support a certain number of wireless devices.
May 06, 2009 | ASUS Eee Pc 1000Ha 160G Netbook
DLINK G604T GENII, DLINK DWL G122 n laptop wireless adapter
It may also be an issue with a firewall on either computer. If you have McAfee, Norton or Windows Firewall enabled, disable it on both side and try the file sharing again. If it works, you will know that you have to check you firewall rules.
Apr 15, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
D-link dir625
What kind of problems are you having? Once the router is connected to your modem and the router is configured and working properly you should be able to connect it to your PS3.
Mar 15, 2008 | Computers & Internet
Wireless router
Has any security setting been enabled or configured before or after your son started connecting to it?
Jan 11, 2008 | Acer Aspire 3680 Laptop
D-Link AirPlus DI-524 Wireless Router Logo
3,900 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
