Question about Brother MFC 240C All-In-One InkJet Printer
Incomplete scanning and copying
Hi, hope someone can help. I have a MFC-240C all in one, and printing seems fine, but when I copy or scan a document to PC only the outer edges of the images show up the center is blank. Even when I ran the scan with the door up and no doc, the center registers as white and not black. Any suggestions ?
Is your scanner glass clean?
if not, clean it tells u hell in the user guide
Posted on Jan 12, 2009
FAILS TO COPY FROM A SCAN
Hi
Scanning takes an image on a document on the scanner's platten and converts it to a digital file format stored on your computer.
Copying is scanning + printing.
To copy, you do not need to separately scan first and then print. Just select how many copies you need on the number pad, then press either the Black or the Colour COPY buttons on the scanner (or open the printer's/scanner's software and click on COPY), while it's connected to the computer and the document will automatically be scanned and printed (copied).
I hope this helps.
Aug 24, 2011 | Office Equipment & Supplies
My mfc240c says to replace the yellow ink cartridge but I don't want to spend money on that if the 'light bulb' is ruined. When I turn on the machine, I don't see any light for scanning or copying. ...
By the "light bulb," do you mean the scanner lamp? That lamp should only turn on when you are actually scanning, faxing, or copying a document. You should be able to still use the machine to scan and fax, even with the yellow ink empty. Try scanning a document to see if the scanner lamp comes on.
As far as printing or copying goes, you won't be able to print or copy anything until you replace the yellow ink, even if you try printing in black and white only.
Apr 19, 2010 | Brother Multi-Function Center MFC-240C...
Prints beautifully from a scanned copy, but light when copying
Check your copy option,constrast to high and quility to Auto.
after that should be fine.
Feb 09, 2009 | Brother MFC-7420 Printer
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Won't scan
I would uninstall the dodgy mydvd program, and use Spybot to clean up the malware it has spread on your system.
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie Brother MFC240c) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
The printer prints from the PC but will not copy without the PC
Please reset your printer to factory defaults form on screen printer menu > > >
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
PROBLEM USING SCANNER
Hi NattyNatty,
The issue seems belong to software. You can remove or repair MFL-Pro software (including in CD-ROM).
Jan 23, 2008 | Brother Multi-Function Center MFC-240C...
Error code cc3-205-03031f02 will not scan
What model do you run? Is it a brother mfc 240c or something diffrent?!!
I ve never seen such an error code for brother mfc 240c printers!
Dec 27, 2007 | Brother Multi-Function Center MFC-240C...
MFC-240c
Remove all the software. Run the worm cleaner software again Restart the computer Ensure you are off line and the Anitvirus program is disabled. Reinstall the software and follow the instruction exactly. Worms don't eat printers
Sep 03, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
115 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
