SOURCE: NVIDIA GEForce 8500 GT
Should be able to find drivers here.....
http://www.gigabyte.com.tw/Support/VGA/Driver_List.aspx?ChipsetType=NVIDIA+GeForce+8500GT
You have to know the model number of you card....
SOURCE: GeForce 8600 GT 256MB DDR3 PCI Express Graphics Card doesn't work
contact the shop / place you purchased it from and they should be able to give you info of where to send it and what to do - they should have a section on there website where you can go through the return process and you will most likely need to get an RMA number to authorise the return / replacement.
SOURCE: I am having problems with my nvidia GeForce 6800
i suspect youyr graphics card is heating up and shutting off to prevent damage. windows will also shut it off but usually repaorts that it did. here is my reccomendation:
1. open side case and place a fan right nest to it. if this makes it work then heat is definitely trhe culprit. if so install a video card cooler or another exhaust fan.
2 turn all the graphics options down on the game. shut anti aliasing off and all options to minimun. then try to play if it still shuts off then your card may be on its last leg from over heating. the 6800 gt was ok when it came out but todays games require more. in fact the newer games won't run on a 6800 gt.
the big thing is heat. the standard 6800 gt just doesn't get rid of enough heat. in fact the 9800 gt i had overheated and burned out. i stay away from gt and now use gtx cards. they have a better cooler and ususally the vent outside of the case.
SOURCE: NVIDIA GeForce 8500 GT 512MB free download
Go to www.nvidia.com and select their Driver and Downloads button.
Enter the fields that pertain to your model of card being 8500GT 512MB.
Remember to select your operating system.
Take care!
damnor01
