Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9400PLO I have a Whirlpool Duet GHW9400PLO and am getting an FdL code. The washer will not start. Several F codes are in the IFU's, but this one is not. Anyone??? thanks.
  • hickeyr1 Jan 06, 2009
    Thanks- I think you guys nailed it!
  • 5,911 Answers
The "Fdl" code is a Door Latch Lock error. Inspect the door latch for obstructions that may be preventing it from locking and doublecheck the wire harness to ensure all the connectors are intact. If the latch is defective, use the following link for advice on how to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Another method of replacing the latch is to remove the top panel and work form the top down behind the front panel. Due to limited space, this may not be desireable to some.
Replacement latches can be purchased on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for your search criteria. These sites have great service and offer competitive pricing. Check out all three for the best savings.
I hope this information helps you. Let me know if you need further assistance.
Posted on Jan 06, 2009
  • 640 Answers
Door lock error,,replace door lock
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Fix your F11 fDL code forever....
STOP the insanity....that's what you're saying if you encounter the F11 and/or fDL error codes on your washer. If you're not there yet, you will be soon....
The dreaded F11 and/or fDL codes - been there done ALL that!! Our Whirlpool DUET washer is just over 5 years. We experienced our first F11 code 6 months ago (warranty just expired what else is new?). When it first happened, I thought nothing of it - hit the cancel button and the machine reset itself. Then it happened again and again and again. Each time it happened it was more challenging to reset it. I searched for the fix on line - I should have done my research before we purchased the washer.
I was able to determine the error was stemming from the CCU board. Order a new one at over $300.00 and have the same thing happen again - I don't think so. We tried EVERYTHING suggested on multiple websites.....unplugging the washer, hitting the right upper side, checking wires, wiggling the wires, wedging things to improve contacts, soldering, re-soldering, Vaseline, changed relays....anything and everything was a temporary fix. Contact Whirlpool directly? Tried that too, they apparently don't recognize there is an issue with F11 fDL errors, "not a commonly called in concern". Really?? We started searching washers to purchase....I couldn't bare spending $$$ for another washer, but we are a busy active family with 4 kids - what are our options? Then one night after searching the websites for one last desperate attempt at salvaging our washer, I followed through on a link:
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2
email: selling.surplus@gmail.com
Now, I'm the biggest sceptic in the world and the most frugal consumer - really I am. I am posting my testament to this service because I've been there - frustrated, disappointed, angry. I am so pleased with the service Ed provided - from answering all my questions, to the superb job he did on the CCU. You can review all the comments posted by all his other pleased customers on eBay. I had to stand by my washer for the first 6 loads - just in case the beep beep beeps started. To my astonishment, amazement, and surprise - it never happened!! In my opinion, this is the only true fix for your F11/Fdl error!!
I never imagined in my wildest dreams ever telling anyone how happy I am to be doing my laundry again, but I really am!!
on May 14, 2010 | Kenmore HE3T Washer
Tip
Fix your F11 FDL error forever.....
on May 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have a whirlpool duet model GHW9400PLO. Husband put a rug in it and now it shows an F2 error and will not drain. We have tried unplugging the machine, that has worked in the past, but this isn't fixing it.
Hi dear.According to your explanation,it's drain problem(F2 code).Please get access machine filter.Check it for any obstacle(Rug Fluff etc...)clean it & run the machine.It should get back to normal.Also check for any kink in drain hose.If that does not work you may need to replace the pump.I hope that helps.Thanks.
Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
TO RESOLVE THE PROBLEM :---
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
NEW CCU for Whirlpool Washer
I found this site, they actually repair the CCU for you. Mainly for the F11 Error Code. I see on the site that they have repaired 95 of them with 100% feedback.
http://cgi.ebay.com/Whirlpool-Duet-Kenmore-HE3T-CCU-Repair-For-F11-FDL-Code_W0QQitemZ230397337074QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a4c05df2#ht_2034wt_1165
Apr 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlppool front loading washer won't start, code FdL, door can be opened
"Fdl" is a door latch FAILURE error code. What the error is telling you is that something is malfunctioning with the electronic door latch and/or interconnecting wire or Central Control Unit. It is recommended that you check the wiring harness connected to the door latch or, replace the door latch. The following link explains how:
If you have any questions or concerns please post back and let me know. I hope this helps you.
Aug 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer not working after a year
F11 means that the motherboard is not talking to the computer that contols the drive motor Fdl is a door lock failure code - i had this exact issue with several and the motherboard resolved it, unfortunately it retails at $324.99
Sep 28, 2007 | Whirlpool GHW9300 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
850 people viewed this question
Dan Webster
Dan Webster
Sal De
