Question about Technics SA-EX500 Receiver
Technics SA-EX500 Receiver audio output problem
Last couple of weeks it has cut out for no reason, turn power off and use next day with no problem. Yesterday it went off and will not come back on. Help Reset button is pushed and it says "operating properly now". No audio what so ever. Need some direction.
5 Suggested Answers
SOURCE: Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Have you checked to see if your fan is still working.....I am having the same issue but I think it's my fan b/c it was doing this when I first got it and for the 1st couple of years.
Posted on Jul 31, 2009
SOURCE: technics SA-DX950
when turn on receiver , after few seconds got message
F70. when wants to do any operation with receiver got message SWITCH POWER OFF
Posted on Sep 24, 2008
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Posted on Sep 17, 2009
Testimonial: "worked like a champ!"
No sound
the service manual http://www.hifiengine.com/hfe_downloads/index.php?technics/technics_sa-500_service.pdf
Jul 27, 2014 | Technics SA-EX500 Receiver
Technics sa gx500
I suppose you did not forget to engage either 'A' or 'B' speaker selectors?
May 17, 2014 | Audio Players & Recorders
WANT TO GET OUTPUT I.C FOR STEREO AMPLIFIER TECHNICS MODEL SA-AX540
Try Ebay or Audio Lab of Ga.
If it's a single module , it wont be cheap
May 01, 2014 | Technics SA-EX500 Receiver
Cannot play my ipod through my technics amp
You would need a mini jack to stereo rca wire. Insert the mini jack to your Ipod's headphones, then plug the stereo rca to your amp inputs. If it's a receiver, plug into any of the inputs (aux, tape etc) except "phono or turntable", then switch to respected input on the receiver. Be sure all volumes on both units are down during this process, then gradually turn up both volume to normal level.
Apr 04, 2014 | Technics SA-EX500 Receiver
User manual
Technics SA-EX500.pdf - Hifi-pictures.net
copy the above ,and paste to google ,the first what google opens is a manual ,just save file to your compute. :) hope i helps
Jan 31, 2014 | Technics SA-EX500 Receiver
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
I need value for R 707 ( resistor on 14v power
You can order a service manual from the manufacturer.
Jun 03, 2010 | Technics SA-EX500 Receiver
Technics tuner amplifier sa-eh750 makes crunching noise and f61 comes up on desplay
I want to change the language on technics hi fi sa/eh750 to english
Jan 30, 2010 | Technics SA-EX500 Receiver
My receiver does not come on and the only thing that turns on is the help and reset button ? I push it and nothing happens
Check your speaker wires aren't touching or that there aren't any shorts in the wires or speakers.
Jan 13, 2010 | Technics SA-EX500 Receiver
117 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
