You might have a job stuck in memory. Message window should say 00%.
Try this
press Function key
press 7 key
press monitor key slowly 4 times
press * key
press 6 key
scroll down to ALL JOB CLEAR
press SET
wait for reboot
Good Luck
function-7-monitor button 4 times, then start [*]- should say service mode then press 1 then 4-5-then start-start - clear then 1 then start then stop - stop
turn off memory and send direct, it will dial, connect then send you will need to make sure that your sending settings havnt been alteredand that you can get an outside line.if that dont work it may be a little more involved, but thats the start
the 400 code is some cases is due to incorrect transmission levels, try turning of memory tx and send directly, or could try adsl filter on the line if needed, there are things that techs will be able to adjust if necessary
