Question about Microsoft Xbox 360 Console
I need an IP adress
Well I have an xbox360 and i tryed to connect the cable that comes with the Xbox360 to my lapt topw, which has wireless Internet, but it says I need an IP adress!!!
  • 34 Answers
U have to change ur sharing settings on ur laptop in connections so ur port will open to let ur laptop and xbox find each other
Posted on Jul 19, 2009
  • Neen39 Aug 13, 2009
    who is ur internet provider ?
I have eveything hooked up so hat i can get on the xbox360 live but it keep sayin that i need a ip adress
You need to get your service providers' settings to be able to use the router for internet connection. If you are just using it to connect your systems for home using and you are not going to the internet, during your setup you will be require to enter an IP Address. Just enter an IP address like 196.254.100.10, subnet mask as 255.255.255.0.
Jun 18, 2010 | Computers & Internet
My ip adresse kepps failing ive tryed manual and auto
if ur ethernet cable is connected to ur modem u dont got to use manual. but u got to use the modem with allot of those ethernet connections, i am using that right now for my xbox360
Mar 31, 2010 | Microsoft Xbox 360 Console
Xbox connected through network cable to pc ! what do i need to perform on pc through my wireless usb port connected to go online
If you are running Windows Vista on your PC here is how you can route your XboX360 through your PC/Laptop in order to get on Xbox Live Wirelessly:
1. Set up a Static IP address in Vista. Go to Start -> Control Panel -> Network & Sharing Center -> Manage Network Connections
2. Right-click on Local Area Connection and go to Properties
3. Double-click on Internet Protocol (TCP/IPv4)
4. Set the option to "Use the following IP address"
IP Address: 192.168.100.1
Subnet Mask: 255.255.255.0
Default Gateway: blank
5. Just to be safe, also set the options to "Use the following DNS Server Address"
Preferred: 208.67.222.222
Alternate: 208.67.220.220
(You may use your ISPs DNS entries also, these are just the OpenDNS ones that should work for everyone)
6. Under the "advanced" tab, you need to check "Allow other network users to connect through this computer's Internet connection."
7. Right-click on your wireless connection, go to properties, click the "advanced" tab and check the same box to allow other users to share the connection.
8. On your Xbox360 go to the network configuration menu and enter the following settings:
IP address: 192.168.100.5
Default Gateway: 192.168.100.1
DNS1: 208.67.222.222
DNS2: 208.67.220.220
Now you should be able to get on the internet with your Xbox as it will be using your PC/Laptop's wireless connection.
Jan 04, 2010 | Microsoft Xbox 360 Console
Xbox360 won't go online after dvd rom replacement cat5 cable OK internet works on other xbox360
hello is the ip address ok try 192.168.1.1 good luck ps dont put any other information in
shaun
Jul 31, 2009 | Microsoft Video Game Consoles & Games
I cant connect my xbox360 or my printer to my cable router
Are you connecting the Xbox via wireless?
Try changing the router wireless authentication to WPA-PSK with TKIP encryption.
XBox and PSP have problems with WEP.
Regards Brian
Mar 20, 2009 | Computers & Internet
My xbox 360 says i need an IP adress
The XBOX is configured for connecting to a router or server that will assign it an IP address. Connect it to your router instead of your laptop.
Jan 06, 2009 | Microsoft Xbox 360 Console
No connection ATALl to internet/live
Okay check the cable of the xbox make sure its not broken or KINKED could have a broken wire somewhere make sure the wire work try the wire on a computer to see if it gets an IP.
Check the connector too, make sure none of the wire are lossen up, if so then replace the connectors or buy a new wire. make sure its Cat 5 or Cat 5E. doesnt have to be cat 6. thats overkill.
if its wireless then check if your router has WEP or WAP enabled, then you have to get the Key to get into the router, and make sure the SSID of the router is correct.
Hope this helps
Good Luck
Rate this please
Dec 19, 2008 | Microsoft Xbox 360 Console
Nat type
I have the same router (WRT300N) and this is what I did. I don't know if it will work for more than one Xbox360.
- Go to the Setting of the router.
- Applications & Gaming
- DMZ
. Enable the DMZ
. Choice the Mac Adress under the Destination.
. If you don't know the Mac Adress of your Xbox360 click on the tab: DHCP CLIENT TABLE
.Now from there choice your Xbox360 ( the Xbox360 won't have a Client Name but hopefully you only have your Xbox360 and your computer)
and now save your setting and restart your Xbox360 and there you go NAT open. This also help if you get any kind of  LAG while someone is on the computer using the internet, your Xbox360 will be high priorty to the router.
HOPE THAT HELP
Apr 05, 2008 | Linksys WRT300N Wireless Router
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
