Question about Microsoft Windows XP Professional for PC
I have a pc running on Xp, and I keep getting this black screen that says that windows will shutdown automatically
  • 66 Answers
Your system are attack virus or some spyware and spam. Try to install Latest Virus Remover
Posted on Jan 06, 2009
PC get shutdown automatically
It can happen in several cases. Like:1. If your processors cooling fan does not run properly or stops running , your processor gets over heated and will automatically shutdown to prevent damage of your motherboard. In this case check this first, If is runs but not seem so smooth, just clean it- dust can jam the cooling fan.
2.If your heat sink under the cooling fan is not perfectly fit on the processor, cooling fan will not able to cool it and will result your machine shutdown!
3. In case of Bad power supply, it can also happen. Check your power supply.
4.If your machine have defected RAM or became defected, it may happen. In this case you may have blue screen with message before shutdown your machine.
5. If you have operating system of Microsoft Windows, please check your hard drive for virus. Virus can shutdown machine with a common period of time! Damaged OS which occurs often in windows operating system also can force to shutdown machine.
Please check which one is in your case. Please mention problem details like something unfamiliar for further query.
Jun 25, 2012 | AcerPower PC Desktop
Tip
Automatically Close Programs at Shutdown
When you shut down Windows, if you have any programs running you'll get a message box warning you that a program is still running. You then have to close the program and tell XP again to shut down. It's a fairly pointless warning—better yet would be if XP automatically killed the programs without issuing the warning. That way, you wouldn't get error messages and wouldn't have to close each individual application before shutting down your computer.
To have XP automatically close programs at shutdown, run the Registry Editor and go to HKEY_CURRENT_USER\Control Panel\Desktop. Edit the AutoEndTasks key so that is has a value of 1. If the key doesn't exist, create it as a DWORD value and give it the value of 1. To disable it, either delete the key, or set the value to 0.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
When i turn on my computer, its automatically shutting down
Can you describe when it shutdowns
1/ After a few text on screen 2/ After Window XP logo on a black background 3/ After Window XP blue screen with username 4/ After logging in
Mar 11, 2011 | Microsoft Windows XP Professional
My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Feb 24, 2010 | Gateway 700 X PC Desktop
Windows XP won't load - black screen
Refresh all the connection on your motherboard like ATX power supply, HDD and CD/DVD ROM cables, and specially the RAM. You may have to clean the RAM as shown in the image below. c4d62f6.jpg
then hopefully your computer will return to normal. Hope this helps.
Sep 24, 2009 | Dell OptiPlex GX280 PC Desktop
Dell dimension 3000. Just Black Screen no Windows XP.
From your description, you were able to boot the machine properly in Safe Mode. While in Safe Mode, change the video resolution to the lowest possible (color depth does not matter at this point). You should also check that you are configured for single monitor operation if your video card supports multiple monitors. Reboot the machine normally. If all goes well, you can readjust your video settings for a higher resolution again.
Jul 06, 2009 | Dell Dimension 3000 PC Desktop
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
Can't get on windows xp?
Have you tried running it in safe mode, then you can restore it to a later date. Or if you have a XP cd, run a repair on windows.
Good Luck
Mar 28, 2009 | Advent 4211c Notebook
Start up problems with Sony Vaio VGN-A517S
remove your screen saver program form computer.go to control panel in settigns u se dispaly open it then set desktop as win xp.
Feb 03, 2009 | Sony VAIO PCV-J200 PC Desktop
My windows xp keep rebooting after shutdown
You should be able to change this setting in the PC bios menu. Windows XP should interact with this and change it automatically, but it occasionally doesn't. If you have trouble finding the appropriate menu and changing it, please post back with details of your PC (ideally motherboard make and model) and we can hopefully talk you through it. When the computer starts up, there should be a screen before the windows XP screen which says something like "press f8 to enter BIOS setup", but all machines are a little different. If you can get into the BIOS setup, only change things which you are sure you know what they will do, or you can cause all sorts of problems. Hope this helps, post back with system details if you need more :)
Jul 02, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional for PC Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
