Question about KitchenAid KGRT607 Gas Kitchen Range
The glass on the outside top of my gas stove/
While boiling some water on the back burner, the glass shattered to pieces. What can I do?
  • Anonymous Feb 07, 2009
    I have the same problem with a GE Profile gas stove: Is it dead?
    Model: JBSP31WET1WW
  • 1,869 Answers
1-877-922-2000 will have your part
Posted on Apr 26, 2009
On our glass top GE Profile stove, the burners do not stay on - they keep turning off and then on again before coming to full temp. Extra long time, for example, for water to boil.
They cycle off once they have reached the temp that you set, then come back on to keep that temp, my suggestion is increase the set temp.
Dec 01, 2013 | Cooktops
I have a Kenmore Gas range. The major stove top no longer gets really hot and we are having trouble boiling large pots of water. It used to be able to boil a large pot of water easily. I would like to...
This could be a problem with the gas regulator, gas supply pressure or the burners need to be cleaned. Here are the cleaning instructions for the burners. If you are still having problems with the burners I would recommend having the gas pressure & regulator checked.
Jan 16, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Jan 21, 2010 | Maytag MER5775Q Electric Kitchen Range
Big chip in glass top burner
If you are looking to fix instead of replace (the better option) you will need to find a ceramic adhesive to put the parts back in place. You arn't going to find it at a hardware store. Try this link. It sells for about $20 bucks.
http://www.waleapparatus.com/catalog.asp?prodid=548630&showprevnext=1
Jan 04, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Roden Gas glass stovetop shattered MODEL GC73H
I have come across this occurence twice before.
With glass stove tops the glass is toughened and can generally withstand most temperatures associated with normal cooking situations. This, of course, assumes that there is sufficient space beneath the cooking utensil (saucepan, frying pan, etc) for air to circulate and the build up of heat to dissipate. If this cannot take place heat will build up to the point that the glass - a refractory material will no longer be able to withstand the internal and external forces created by the differences in internal and external temperatures and will thus shatter.
Though this is generally rare, it is known to take place and users are warned. Incidentally, this is the reason the shape of the glass top is the way it is and not the usual square as with other tops, in order for the heat to dissipate more easily.
In short, you should insist to your landlord that you were not misusing the appliance, but through genuine use this somewhat rare event occurred.
Aug 06, 2009 | Cooktops
How can I clean my GE stove top burner and black stove cap???
Soak the black stove caps in 1 part ammonia and 3 parts water. Let soak for several hours. I let it soak overnight. It should clean right up.
Jun 11, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Glass stove top has a piece that has peeled back
once they are broken they are broken you have to replace he whole top
Feb 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Stove top burners on glass stove seem to have a governor on them
My initial attempt at solving the problem was to contact the GE customer service phone line.  When I explained the problem, the representative had no clue how to solve it, and referred me to the service organization.  The representative at the service organization was equally clueless, and suggested scheduling a service call at $100 plus parts and labor.
This is all quite disappointing; these customer and service representatives obviously have no training in solving the simplest of problems.  This is okay if GE's goal is to maximize service revenue.  But, I can tell you I would be very unhappy to have a technician visit my house, for $100, only to be told I was using a pot or a pan that was designed incorrectly for a glass cook top.
I solved the problem by going to the web site www.geappliances.com, opening the user manual, and looking under trouble shooting.  The first problem mentioned is exactly as described above.  The problem is inappropriate cooking appliances.  It is not possible to transfer heat efficiently if the pot you're using has a rim or lip on the bottom.  That is, the pot must sit flat on the glass cook-top, it cannot be raised off the cooking surface by a lip that elevated the pot from the surface.  These pots are designed to be used with gas flames, not a glass cook top.
Dec 08, 2008 | GE Profile JTP18 Electric Single Oven
Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Apr 29, 2008 | Cooktops
KitchenAid KGRT607 Gas Kitchen Range Logo
197 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
