Question about Compaq Presario R3000 Notebook
Ram upgrade = computer will not load
I inserted 1 gb of ram on my Presario R3000 in the slot next to the batter and the inital 'compaq' screen comes up but just stays there. The laptop worked 2x without stalling at the compaq screen, but froze shortly afterwards.
The ram is made by samsung, bought from crucial.
A site checked prior to purchase said this was compatible, but it doesn't work.
Any suggestions? Thanks
  • jackiegolon Jan 06, 2009
    I have reinstalled it several times but it always causes the frozen compaq screen.
    I also went to download bios and drivers but already had most up to date versions
  • Anonymous Jan 08, 2009
    im having the same problem
  • 366 Answers
Reinstall the RAM.
Clean carefully contacts.
Ground yourself to avoid any electrostatic discharge
Posted on Jan 06, 2009
  • 69 Answers
Maube your ram has a fault, can u check it out on a other notebook
also i recomend to do a firmware upgrade for ur notebook because in a firmware there a lots a bug fixes for your notebook also it makes your notebook compatible with other ram modules and cpu´s
go here and choose your notebook from this list
than upgrade your notebook with the latest bios and drivers
and let it hope it works
  • etienne meerwijk-joffel
    ok, than i think your ram is maybe broken or corrupted if u have warranty on the ram modules than go back where u did buy then and take ur notebook with u so that the can see it for them selfs and try other ram modules in the shop where u buy the ram.
  • 741 Answers
First check out the RAM you had prior. If it is DDR or DDR2 then it needs to match exactly. If you go to the HP website and type in your model number they can tell you what RAM is compatible. If it matches what you bought and its not working then the RAM is bad and needs to be sent back.
Please rate this solution and thanks for using FixYa.
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
Apr 20, 2013 | HP Compaq Presario SR1215CL (82916052980)...
I have an HP Compaq Presario SR2011WM PC Desktop Intel Celeron with 512MB RAM. Its too slow, what should i do? Can I upgrade the RAM to 2GB? Thank you.
2 GB (2 x 1 GB) Speed supported PC2-4200 MB/sec Yes, you can add memory:
2 GB (2 x 1 GB) PC2-4200 MB/sec,240 pin, DDR2 SDRAM
2 GB (2 x 1 GB)= 2-1 GB. modules for each slot, for a total of 2 GB.
Make sure that yor run the defragmenter:
How to use the Windows Defrag tool:
To start Windows Defrag, double click on the "My Computer" or "Computer" Icon on Desktop or in Start Menu.
Next Right click on the "C:" drive (Or the drive you wish to Defrag) and select properties from the list that appears...
From the next menu select "Tools" and then "Defragment Now"
The Disk Defragmenter screen will now appear, Click on Analyze. This will check your drives and will only take a few seconds. If your result shows a lot of red like mine (see picture below) then click on "Defragment" to continue) Be warned this may take several hours, so don
Feb 26, 2011 | HP Compaq Presario SR2011WM PC Desktop
Can i put a 2 gb ram upgrade in my compaq presario cq-60 along with the existing 1 gb ram that the computer came with
probably not ... traditional wisdom says memory chips should match for best results and I think there is only two slots ...
if you are physically able to do this ... same number of chips as slots ... take out the old ... put in the new and try it ... then turn it off again ... put in the old ... the worst thing that will happen is your computer will not boot.
Aug 12, 2010 | HP Compaq Presario CQ60Z Notebook
Can i add 2g of memory to a compaq presario r3000, if so, where is the seconf memory slot?
Yes your computer is compatible with 2GB of Ram.
The second Ram module is located under the keyboard.
Please do not hesitate to let me know if you need any further assistance.
Kind regards
Feb 18, 2010 | Compaq Presario R3000 Notebook
Windows wont load after memory upgrade Presario R3000
Some time this type of problem occurs either one of you memory module is not working properly check your memory updation in bios then reinstall the windows after ram ugrade ,reinstllation after memory upgrades solves this problem
Aug 16, 2009 | Computers & Internet
Upgrade memory for Compaq Presario R3000 PC Notebook
What OS are you running? 768 should be enough to run XP and keep you from getting that error message. On laptops their are normally just 2 slots for ram, so you would need to replace the 256 with the 512, which would bring you up to a gig of ram. Do you know if your computer has any spyware/adware on it? Sometimes malware can take up all your memory and generate just such an error. Do you know how many processes are running when you first login? Thank you.
Apr 10, 2009 | Compaq Presario R3000 Notebook
Location of memory slots
Hi.There are a set of instructions that we need to follow for the upgrade process.You can increase the amount of RAM (random access memory) in the notebook with an optional memory module approved by Compaq.The notebook contains 2 memory slots, one of which is accessible for an optional memory module upgrade.Please refer to think link and select the Hardware Upgrade option in the list in the file which will guide you thru picturised views for helping in the memory upgrade.Link is :
Please let us know whether this help or whether you need more help
Mar 16, 2009 | Compaq Presario R3000 Notebook
Upgrade ram
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot. 2 slots=1 gig or 1024MB ram.
May 22, 2008 | Compaq Presario M2000 Notebook
Compaq Presario R3000 Notebook Logo
117 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
